Old 03-28-2017, 11:16 PM   #1
karrlot's Avatar
Coachwork: Ward
Rated Cap: 65 passenger
Recommendations for Seam Sealer
I am looking for recommendations for seam sealer for the roof. If you have used the type that come in a caulking tube, please let me know which brand and model number. How has it held up? How easy was it to apply?
Please check out my blog-
Follow the (lack of) progress on the Karr Family Kamping Bus Blog
Here is my woefully inadequate build thread:
https://www.skoolie.net/forums/f11/i-...bus-12296.html
karrlot is offline   Reply With Quote
Old 03-29-2017, 06:11 AM   #2
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
I use both solar seal and pl1, both are eurathane based sealants. it takes mineal spirits to clean up. ive used this stuff for 20 years . ive had it on my bus 2 years with no problems. comes in many colors.
my build pics
Old 03-29-2017, 06:27 AM   #3
Chassis: 3800 Carpenter
Engine: DT360 / AT545
I'm planning on using Eternabond Webseal then painting over it. Haven't used it yet, but saw it mentioned in threads here.
oredigger is offline   Reply With Quote
Old 03-29-2017, 09:12 AM   #4
3M Seam Sealer is an OEM grade product and as good as it gets. Is paintable and will last the life of the vehicle. I ordered mine online here...
https://www.autobodytoolmart.com/
3M Urethane Seam Sealer, Black, 310 mL Cartridge - 08367
SKU: 3M-08367
NOTE...available in several colors
Old 03-29-2017, 11:49 AM   #5
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
Yep.........
Originally Posted by tango View Post
3m seam sealer is an oem grade product and as good as it gets. Is paintable and will last the life of the vehicle. I ordered mine online here...
3m urethane seam sealer, black, 310 ml cartridge - 08367
sku: 3m-08367
note...available in several colors
Old 03-29-2017, 01:27 PM   #6
Chassis: Gensis
I highly recommend using Ames Maximum Stretch paint and their seam tape. Used it on my bus because I was also concerned that it could leak. This stuff is designed to flex and is made for metal roofs. It is a strange material but after going through a brutal snowy and wet winter it worked as expected. It also cools the bus down a lot in the summer. I have pictures in my album and more details in my build thread.
The paint and seam tape total was like 200 and I hit all of the seams on the roof, around the vents, and the edge seams as well.
Second Star Skoolie Project
Crozz is offline   Reply With Quote
Old 03-29-2017, 01:43 PM   #7
SKU: 3M-08367
Good stuff!
3M makes good products, imo.
Old 03-31-2017, 05:14 PM   #8
Engine: T444e
Rated Cap: 35
I used 3M Dynatron 550 seam sealer to fill the seat/screw holes in my floors and to fill in the seams between floor panels so there is nowhere for moisture to hide.
bstewrat3 is offline   Reply With Quote
Old 04-02-2017, 05:46 PM   #9
Engine: t444e
Np1
Sent from my SM-N900T using Tapatalk
ChiliChzPoopTart is offline   Reply With Quote
