Old 05-08-2017, 01:18 PM   #1
Coachwork: Thomas Saf-T-Liner
Refinishing original windows
Hi,
I've been searching around the internet to find some new rubber gaskets for my windows. I'd like to use my school bus windows but the rubber gasket around the glass is all cracked/dry/broken. Would anyone know of a source for new gaskets or a method to seal them up? I was thinking about trying to use butyl caulk but not sure how well it would work. I did find out new latches are only 85 cents, probably the cheapest part yet.
Sent from my Nexus 6P using Tapatalk
nwarner2010 is offline   Reply With Quote
Old 05-08-2017, 01:25 PM   #2
Robin97396's Avatar
I hate to say it, but a automotive glass shop should be able to either sell you the supplies you need or be able to tell you where to get what you need.
Robin
Nobody's Business
Old 05-08-2017, 01:27 PM   #3
That's where I'm headed after work to see what they say. I have a couple broken windows that need replacing too, so I'll get a quote for those while I'm there.
Old 05-08-2017, 04:21 PM   #4
tobeamiss's Avatar
How about busparts.com ...
oh yes she did!
https://www.skoolie.net/forums/f11/to...-it-16557.html
Old 05-08-2017, 05:48 PM   #5
I tried them, no luck. Waiting on Thomas to get back to me but doesn't look like they stock them anymore.
The glass shop said to just use silicone​. The glass seems really loose in the frame for just silicone. I guess I can try one and see how it goes.
Old 05-09-2017, 03:21 AM   #6
tobeamiss's Avatar
Autopartswarehouse.com
Or Google....
"buy bus window gaskets"
When I did that I saw some things you might be able to use.
oh yes she did!
Old 05-12-2017, 08:02 PM   #7
I've been searching for a few more days, didn't come across anything. There are companies out there that will make a custom seal for you but it wasn't cost effective. I've decided to use the old seals as a sort of spacer and silicone between the frame and the glass...we'll see how well it holds up.
Old 05-12-2017, 08:58 PM   #8
Robin97396's Avatar
Good choice. Butyl would have been to thick.
Robin
Nobody's Business
Old 05-16-2017, 06:35 PM   #9
If anyone runs across this thread looking for new rubber gaskets for their windows I think I may have found them:
https://www.amazon.com/CRL-Glazing-V.../dp/B00O8ZUM6K
This looks very similar to what I took out. They also have various different sizes available.
CRL83R-030714_471.pdf
Old 02-08-2021, 07:19 PM   #10
Year: 1994
Chassis: Saf-T-Liner ER
Engine: 6.6L CAT 3116
God bless you Nwarner2010.
Sincerely,
Me in 2021
GrassMonster is offline   Reply With Quote
Old 02-09-2021, 02:01 AM   #11
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
McMaster-Carr has an abundance of seals / weather stripping. Might be worth checking out.
Ted
Old 02-09-2021, 07:34 AM   #12
Year: 1994
Engine: DT408 6.7L L6
This is an old thread... now that I see this, I can't delete this reply... Leaving it for posterity.
Thomas does carry the parts, it's in their accessories manual. Check here for the part #, then call Thomas and ask for the price. When I priced mine out a couple years ago, I believe it was about $3.50 per.
https://midwestbussales.com/wp-conte...10394-2006.pdf
~Alf
My Build Thread!
djdalfaro is offline   Reply With Quote
