Old 08-21-2018, 05:54 PM   #1
Coachwork: Freightliner Thomas
Engine: 5.9L Cummins Diesel
Rated Cap: 71
Reflectix alternatives?
Hi folks,
It seems a lot of folks use Reflectix or some similar product to improve thermal conditions. We are sensitive to lots of materials and it seems Reflectix likely won’t work for us (new plastic is generally not good for us; we tolerate it in small quantities, but wrapping our house with it seems like a bad idea).
Thoughts on using sheets of aluminum foil instead? Other ideas?
olives is offline   Reply With Quote
Old 08-21-2018, 06:14 PM   #2
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
https://www.insulation4less.com/Insu...aspx#fragment1
Old 08-21-2018, 07:54 PM   #3
Originally Posted by olives View Post
Hi folks,
If you glue mylar to bubblewrap you've just made your own "reflectix".
Old 08-22-2018, 07:12 AM   #4
Chassis: International 1753
Engine: 6.9 International
Reflectix isn't so much the aluminum foil, but the air gap created by the bubble wrap.
So if you're using it internally, the aluminum foil is somewhat useless.
Old 08-22-2018, 08:01 AM   #5
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Howdy Olives!
Reflectix is generally a poor performing product. There are a number of good evals online. As I recall, it relies on a huge air gap and is more about thermal "reflection" (reducing heat gain) than actual "insulation" (I could be wrong/mis-characterizing). In any case, better options include foam, classic insulation (fiberglass/denim), and air gaps. However; they all involve 'materials' so the trick is probably finding one that doesn't bother you.
I installed mylar behind windows that I was covering over to reflect the suns heat but again, it offers no insulation value.
JD - Full timer out west
My Adventures & Build
insulation, reflective
