Old 10-01-2005, 10:28 PM   #1
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
refrigerator, water pump, and furnace advice.
I am aquiring new appliances for the bus reno.
Here is where I am at. I have the winter to aquire new appliances for the bus and I am looking for suggestions.
No 1. Water pump brand and size. I would like to know what has worked for people and what they could do differently now.
- how many gpm?
- automatic flow sensor or an on/off switch?
- acumulation tank or no?
No 2. Furnace. I currently have a vented, non ducted or fan assisted propane furnace. It works well, however is not very efficiant and allows air to flow through the vents to the inside of the bus while not in use. And it needs work. So I am thinking of replacing it.
- How about a non vented propane (brick) style?
- Under bus with ducting and squirrel cage?
- Other?
No 3. Fridge. I need a fridge. I would like the versatilitly of a 3 way however the price is duanting. I have seen a number of people use domestic electric styles on this site and am wondering how much juice they use. Are the designers planning on using their busses for boondocking or are they reliant on generators? I like the price of a used domestic full size fridge, but I am concerned with how much battery it will use.
No 4. Please recomend and air conditioning unit. I would like two ceiling unit's with heat strips.
- what brands are the strongest?
- what should I look for when purchasing?
Thanks to all of you. The diverse opinions and experience on this site are a value to all.
- Richard
captainkf is offline   Reply With Quote
Old 10-02-2005, 04:03 PM   #2
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Honestly, unless you have a specific requirement for refrigeration such as medicine, I'd suggest that you consider NOT getting a fridge. I've been doing without one since may, and it's really not difficult. You automatically lose the expense and upkeep of it, plus you gain the space it would have taken. Plus you don't have a fridge full of leftovers going bad!
Eric von Kleist is offline   Reply With Quote
water pump gbstewart Plumbing, Water and Waste 5 11-11-2010 03:41 PM
12V Water pump for fresh water? ezbme Plumbing, Water and Waste 1 05-29-2009 06:26 PM
Diy wood/water furnace? gotmuddy Conversion General Discussions 12 05-16-2009 09:24 PM
Water Pump Help FelixM Conversion Tutorials and How-to's 4 04-10-2009 09:32 AM
15k Heat pump install advice JonCBrand Conversion General Discussions 6 04-30-2007 08:10 AM
