Old 01-29-2018, 11:09 AM   #1
Question Removable shower base
Hi All.
A few weeks ago I bought a motorhome that came with all the things I need it like the stove, 3 way fridge, LPG tank, freshwater tank, sink, shower enclosure and much more. What I really needed was the fridge and stove but since all the rest was in good shape I took it too and then the question began....should I have a shower in my shorty ? ( 4.5 window chevy bluebird 2002), then during the same week I saw an ad in CL about a winnebago lesharo parts for sale and I bought the shower/bathroom all in one enclosure from it.
for those that don't know this motorhome, here is a picture of the bathroom :
This things are very cool, you push those little silver buttons close to the side handles and you pull the bathroom walls forward and if you want to take a shower you remove the cover in the floor and set the curtain and you are set but that work well in the lesharo where the floor is setup for that but in my bus is not like that.
I don't want cut the floor to insert a shower base since I already installed hydronic heat so I thought about installing a drain that I can cover when not in use and get a shower pan/base that is low profile and that I can have ready to plug into the drain when needed.
Have anyone done that ?
Any other solutions for this ?
I will like to keep the wall system of the lesharo bathroom so whatever solution I find hopefully it can fit inside.
Thanks.
pepepito is offline   Reply With Quote
Old 01-29-2018, 02:30 PM   #2
Robin97396's Avatar
That's impressive putting a shower into a real shorty. I'm following this.
How did your hydronic heat do this winter?
Robin
Nobody's Business
Old 01-29-2018, 02:34 PM   #3
haha I haven't used once, I'm about to connect it soon.
Sent from my ONE E1005 using Tapatalk
Old 02-18-2018, 07:08 PM   #4
I'd also be interested to hear about your hydronic heat!
I'm putting in radiant floor hydronic heating run off a coal-fired wood stove in my current build, but am still a few months away from installing it. Lots of design to do still!
Professionally converting vehicles and making custom furniture with a combined 14 years of mechanical/electrical engineering experience.
https://www.thunderstruck-studios.com/
ThunderstruckStudios is offline   Reply With Quote
