Old 03-23-2012, 04:54 PM   #11
Re: Remove or Not to Remove - Rubber Floor...
sorry about that Lorna, with all your know how , you pass with flying colours, Im sure you have had plenty of war wounds
Old 03-23-2012, 07:11 PM   #12
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
I left my rubber floor in. There is no plywood underneath it. I did an extensive viewing of the underneath of the bus and determined that the metal floor structure was not rusted.
I covered the floor with 3/4 inch blue board insulation and then put down 3/4 inch hardwood flooring. I have no "old bus" smell.
BUT THEN, I have two dogs who make their own smells, and the older I get, the less my nose works.
At least my ears still work well. Not so for my eyes.
"What a drag it is getting old".
Old 03-23-2012, 07:21 PM   #13
bus-bro's Avatar
Engine: 3208 na boat anchor
I was going to pull the rubber and see if the plywood was OK (my bus was the steel, plywood, rubber variety.) That didn't work. It was easier to pry up the plywood, with the attached rubber, with a long wrecking bar. Not all that much work, just some brief periods of hard muscle use. I had surface rust, and areas with bad plywood. Water came up through the seat bolt holes and caused localized problems. It was a western Washington bus, so it ran on wet roads alot. I floored it with t&g 3/4" plywood over 1" pink foam board. Ran about $10 a foot of bus length.
Old 03-23-2012, 11:27 PM   #14
lornaschinske's Avatar
Rated Cap: 89
I wonder why some Blue Birds are rubber on plywood, on metal and others, like ours, are simply rubber on metal?
Fulltime since 2006
Old 03-24-2012, 08:24 AM   #15
usmcbay's Avatar
Coachwork: Thomas MVP
Chassis: Saf-T-Liner ER
Up early this morning with the kids... heading to my Folks to pull the Rubber Floor and put down the 1/2" Foam Board and 1/2" Plywood... Remove Vinyl Stickers and possibly roll on the Primer... we'll do what time allows!
Here's my Bus Conversion...
viewtopic.php?f=11&t=12202
usmcbay is offline   Reply With Quote
Old 03-26-2012, 09:27 AM   #16
usmcbay's Avatar
Well here it is... and let me say~! Wow... what a chore!
First off... the Center Isle strip just pulled right up with no problems. The Seat Row Rubber was a different story... closest to the wall it came right up from the heat/degradation. Closest to the Center Isle was okay too just a lot of Bolt pieces to work around from Cutting the Heads off the Seat bolts. But the 70% of the Middle you HAVE TO HAVE a long handled Iron Scraper or work your life away with a Flat Shovel... anyhoo... Got it done! Thanks to my Parents help we knocked it out and lost lots of Water Weight in the process... Another thing - It took up 7 Mega Thick Ultra Heavy Industrial Strength Bags... the problem is Weight. Honestly the Floor weighs in around 400lbs-500lbs. I'm 200lbs and I figure it weighed AT LEAST two times my weight if not more. Also the amount of pennies, dimes, and quarters well makes up for any labor spent! (Value based on 1775 labor wages~!).
So enough said here are some Photos...
Old 03-26-2012, 09:57 AM   #17
usmcbay's Avatar
Add'l Photos...
My Dad really helped with the Flooring... my Mom helped with the Decal Removal, Bagging Trash, Covering Painted "School Bus" signs and cleaning everything that needed cleaning... they were both amazing help and love doing these types of projects. I have the best and hardest working parents in the World~!!!!
Old 03-26-2012, 10:03 AM   #18
usmcbay's Avatar
Floor Going down...
Old 03-26-2012, 11:13 AM   #19
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
looks good but no sealer/paint job first?
Old 03-26-2012, 12:46 PM   #20
usmcbay's Avatar
Yea... we talked about that... The floor was in such "Good Shape" and the Foam board has the Vapor Sheathing. If I would have had it I would have done it but I didn't so I didn't. Just one of those things in hind sight I suppose. I am going to Caulk all of the edges and spaces... I spaced all the Plywood 1/8" gap from each other so that it would'nt start to rub and squeak later on while walking on or traveling down the road. Also a 1/4" gap along the edge against the wall. All of this will be caulked and a Sealer put on top of the Plywood then additional vapor barrier above that - which will be below the Laminate Wood flooring. I want to know that if something leaks or spills it is not getting to the Foam Board~!!! Also we caulked the floor holes and put down Aluminum Tape. All an effort to block any potential moisture. Also I sprayed Rust Inhibitor around the Wheel wells where the worst rust was noticed... and that was AFTER hitting it with a grinder to knock any scale off. So... no we didn't seal the floor however every attempt was made other than that to eliminate the potential.
But again... it would be and is a great suggestion to do it!
Remove rubber flooring. wmkbailey Conversion Tutorials and How-to's 11 11-27-2014 09:47 PM
Remove stock heaters, or not? MikeyBskunk Conversion General Discussions 9 12-03-2010 04:57 PM
How do we remove the windows? gbstewart Conversion General Discussions 4 06-03-2010 08:11 AM
Remove rubber floor?? and wall panel body strengthening?? adamanderr Conversion General Discussions 10 01-06-2008 12:49 AM
how to remove sidepanels ???? swinada Conversion General Discussions 3 05-21-2007 06:30 PM
