Old 02-23-2018, 12:22 AM   #1
Remove plywood without removing rubber flooring?
Yeah I just wanna know if anyone has tried this:
I was thinking of pulling up just enough of the rubber floor to find the seams of the plywood and then Use a heavy duty box cutter/laminate tile cutter to cut the rubber along the seams and then just going straight to lifting up the plywood. Just seems like ripping up the rubber is an unnecessary step if you’re just going to pry up the plywood. Anyone have some insight as to why this is or isn’t a good idea? Anyone tried it? Thanks in advance!
Mbethc33 is offline   Reply With Quote
Old 02-23-2018, 01:00 AM   #2
Jdawgsfanasty's Avatar
I've heard of people getting a car jack under the plywood and using that to pry it up...if that would work then the rubber would stretch and be easier to cut
Jdawgsfanasty is offline   Reply With Quote
Old 02-23-2018, 09:00 AM   #3
Robin97396's Avatar
Demolition is done any way that works best for you. The rubber mats are fairly heavy, but if you can pull them together by cutting the seams it would be a good thing.
Robin
Nobody's Business
Old 05-31-2019, 04:58 PM   #4
Chassis: 3000
Engine: 466DT w/ Allison MD3060
This is how I removed my rubber. Worked great!!!
67B9AC58-C8B5-4D73-B97D-92D7D8FA93AC.jpg   24745ACB-B2F3-4E59-81C5-4A9F427F4A31.jpg   80F985D6-A10B-493B-B7CC-91B71B09069B.jpg
DaddybearGheor is offline   Reply With Quote
Old 05-31-2019, 05:00 PM   #5
HazMatt's Avatar
Chassis: IH 3800, 8 window
I was almost afraid to let the pictures completely upload...
Old 05-31-2019, 05:05 PM   #6
Chassis: 3000
It went so much faster then when I first tried using shingle shovels and pry bars lol.
Old 05-31-2019, 06:32 PM   #7
HazMatt's Avatar
LMAO
I have no doubt!
yee-ouch [emoji856]
flooring, laminate, plywood, rubber
