Old 01-06-2008, 12:49 AM   #11
KC10Chief's Avatar
Rated Cap: 60
Re: Remove rubber floor?? and wall panel body strengthening??
Your bus is probably quite a bit different than mine. Do you have any shut off valves? They look a lot like the spigot on the side of a house. You'll probably have to do it from inside the bus. It doesn't really matter either way. Right now, I just have a length of hose that I folded over and connected to both tubes. I'll take some pictures of it for you tomorrow in the daylight. You have coolant going to the heater, flowing through it and then back to the engine. You can totally pinch off the lines and the coolant will still flow through the engine just fine. Anyways, I'll get some pics for you tomorrow afternoon sometime!
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
http://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Remove or Not to Remove - Rubber Floor... usmcbay Conversion General Discussions 29 01-14-2017 05:44 PM
Remove rubber flooring. wmkbailey Conversion Tutorials and How-to's 11 11-27-2014 09:47 PM
Body panel parts. crazycal Conversion Tutorials and How-to's 3 06-21-2014 12:50 AM
Rubber floor recycler Conversion Tutorials and How-to's 2 06-08-2009 02:40 PM
No wood under rubber floor wmah Conversion General Discussions 3 10-20-2005 08:58 PM
