Old 03-10-2018, 06:16 PM   #21
ak91th's Avatar
Coachwork: Ward
Chassis: 1975 White Road Boss
Engine: Detroit 8V71/330hp.
Here is a link to a rivet removal tool for different size rivets. https://www.aircraft-tool.com/shop/detail.aspx?id=1341A
It is used a lot in the aircraft industry. Hope it helps.
JD - Boss75
______________________
Live from the last frontier
ak91th is offline   Reply With Quote
Old 03-10-2018, 06:26 PM   #22
Sojourner, is that a 100 gallon tank you dropped from yours? Looks like a bigger job than I was picturing in my mind.
Old 03-11-2018, 06:06 AM   #23
sojourner's Avatar
Engine: DT408
Standard 65 gallon fuel tank, in case that's what you're referencing.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 03-13-2018, 01:25 PM   #24
I don't have tractor cheater, so I'll have to see what a nightmare my 100ga. will be to drop and clean.
Old 03-13-2018, 02:07 PM   #25
I am having some success grinding the heads off and punching the body out with my air chisel.
Unfortunately, a number of them on the chair rail are not punching out. I am going to have to figure out how to deal with those.
I managed to do a little body damage and break a couple of windows as well
Old 03-13-2018, 02:12 PM   #26
sojourner's Avatar
Engine: DT408
If you set it up correctly with a couple floor jacks and an extra set of hands you should be able to do it fairly easily. Patience with an eye for safety is the key here. Its mostly just me working on this thing so my tractor is just another set of "hands". I ran my own mobile marine business for a good number of years so I'm pretty adept at moving heavy things around alone.
Old 03-13-2018, 02:13 PM   #27
sojourner's Avatar
Engine: DT408
I got one myself. Thankfully I'm only using a few of the windows in mine. I'll still have lots of spare parts when I'm through.
Old 03-13-2018, 02:34 PM   #28
Took me a minute......
I started reading that and wondering "how in the heck is a floor jack going to help?"
Old 03-13-2018, 03:53 PM   #29
sojourner's Avatar
Engine: DT408
Sorry, I think this thread got hijacked a bit.
When I removed my rub rail rivets, I removed all of them and removed the rub rail altogether. I then go around with a hammer and a roll pin punch a bit smaller than the shank of the rivet that's been cut short (so it doesn't bend) and with a 1 or 2lb hammer to knock the rivet shanks out. You have to whack it hard all at once though to shock it through. I've also used vise grips on the inside and clamp on and wiggle them loose and pull from the inside.
Old 03-13-2018, 05:49 PM   #30
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Just catching up on this one?
And I might have missed a part?
If your interior walls are off and the ribs exposed? Why not cut the interior side of the buck rivet flush to the rib and punch it out instead of trying to cut the head off.
