Old 09-30-2010, 01:36 AM   #1
Coachwork: Unsure
Chassis: Chevy Van 30
Engine: Chevy 350
Rated Cap: 16
Removing Floors
How are the wooden floors attached?
Mine is a Chevy van 30 chassis, 4 window Short, to be delivered soon.
Any recommendations for removal?
pipsqueek is offline   Reply With Quote
Old 09-30-2010, 01:53 PM   #2
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Removing Floors
The plywood in my bus was attached with special fluted nails. The nails were attached to the floor pretty well by rust as well. I found that a large chisel and a 6' long pry bar was the key to getting the plywood up in large chunks and sometimes even in one piece. First I would hammer the chisel under the edge, maintain the torsion by inserting some object (bricks, logs, or whatever), and then come in with the pry bar. I'm sure this would work with screws too, since the wood just rips over the head. Then you go in with a claw hammer or crowbar to pull out the nails; or if screws take your pick of vice grips or angle grinder, etc.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 09-30-2010, 02:06 PM   #3
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
Re: Removing Floors
Mine had a (large) number of #14 x 1" screws. Once I got those out (or at least spinning), I used a large pry-bar to get them up after I'd taken off all the nicely curved trim where the walls met the floor.
Also, if you have exit doors, check to make sure you've taken off any angle protectors before you start to pry, as they can really hold strongly.
That said, my floor came up in sheets that stayed pretty much intact.
Best of luck!
Hex is offline   Reply With Quote
Old 10-04-2010, 12:51 PM   #4
millertime's Avatar
Year: 74
Re: Removing Floors
"gobucks" pretty much hit on everything. We just finished tearing out the floor in our '74 Bluebird and the floor was just about all rotten at the front and rear of the bus. We were lucky enough that most of the screws did come out. I used a impact screw gun to remove the screws so that it didn't immediately strip them. One suggestion i do have is that there is a metal trim piece where the front door stairs meet the floor. I recommend saving that piece if at all possible because you will never find another piece bent that way.
millertime is offline   Reply With Quote
floors and walls jjhomeonewheels Conversion General Discussions 12 03-28-2018 04:07 PM
Tile floors in bus, has anyone done this? Almanzo Conversion General Discussions 5 07-03-2014 10:13 AM
Floors bus-bro Conversion General Discussions 1 04-08-2013 10:57 AM
Who here has tiled their floors? lornaschinske Conversion General Discussions 2 05-18-2010 04:30 PM
Bus floors/plumbing wmah Conversion General Discussions 0 08-14-2006 06:15 PM
