Old 04-11-2018, 06:38 AM   #1
Hobotang's Avatar
Rated Cap: 83
Removing On board AC - SEE PICS - Help
Hey peeps,
I a ways into my conversion on an 1989 Bluebird All American with an 8.3 Cummins in the front. I’ve removed everything AC related but pictured items below: hoses, and AC motor?, and belt?
I’m moving the rig to a new plot of land in Knoxville and need to know if capping these connections are ok, or if I should be removing the entire unit.
Thanks in advance for the input.
https://www.amelia-bartlett.com/the-skoolie/
Hobotang is offline   Reply With Quote
Old 04-11-2018, 06:52 AM   #2
joeblack5's Avatar
Year: 98
You can plug them to avoid contamination. Be sure that you remove the AC clutch wire so that the pump does not gets activated. Ifthe belt only drives the Ac pump then remove the belt.
Good luck.
later J
Old 04-11-2018, 06:58 AM   #3
Hobotang's Avatar
Rated Cap: 83
Thanks joeblack5 - on my way to investigate
Old 04-11-2018, 07:17 AM   #4
what joe said, unplug it, and pull the belt if it only drives the A/C compressor.
