Old 03-05-2010, 08:57 PM   #1
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Removing rivets from rubrails
What is the best method for removing the rivets from the rub rails. I have decided that I don't need the rub rails and think it would look better without them. I thought about grinding a flat spot and drilling them out, but there are about 2.5 million of those little buggers on my bus. Who has removed their rubrails and how did you deal with the rivets?
Old 03-05-2010, 11:16 PM   #2
Chassis: C60
Engine: Chevy 7.4l 454 FI
Rated Cap: 59
Re: Removing rivets from rubrails
sharp air chisel will pop the heads right off or you can use a grinder with a cutoff wheel as well.
ramairws601 is offline   Reply With Quote
Old 03-06-2010, 04:59 PM   #3
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
That is a neat tool. What about cutting an X in the head of the rivet with an angle grinder, then hitting it with a hammer and chisel? That should do the job shouldn't it?
Old 03-06-2010, 05:25 PM   #4
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Yes, if you have plenty of time and patience, and don't mind the effects of grinding too deep occasionally.
bus-ted is offline   Reply With Quote
Old 03-06-2010, 06:58 PM   #5
Can you grind the back off of them on the inside and just hit every other one with a hammer? Let the rubrail fall off and take them with it?
Old 03-07-2010, 06:33 AM   #6
maj
Coachwork: carpenter
Chassis: spartan
Engine: 5.9 cummins
When you remove the rub rails will the sides loose any structural strength?
maj is offline   Reply With Quote
Old 03-07-2010, 07:42 AM   #7
Chassis: C60
Rated Cap: 59
yes they will, I notice my panels arent as strong now and the bottom edge is the worst obviously. I plan to add crossmembers behind them so it will be solid again. alot of work but worth it to me to have a smooth exterior.
Old 03-07-2010, 01:00 PM   #8
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
My plan is to remove the bottom rub rails and relocate them behind the panel. This way it keeps the strength and allows me to extend the body down even with the bottom of the entry steps. I will gain room for additional underbody storage boxes. I am planning on using aluminum treadplate along the bottom of the body to do this. It will lower the body about 7" and still give me 12" of ground clearance. The relocated rub rail will add stability and keep the body from folding under. I have decided to leave the other rub rails in place...my wife seems to like them.
Newly Purchased Skoolie - Tips for removing rivets and floor Alexlorraine01 Conversion General Discussions 7 07-01-2016 09:25 PM
Removing internal rivets timbrass Conversion General Discussions 11 07-01-2015 08:15 PM
Rivets Zephod_beeblebrox2 Conversion General Discussions 4 10-15-2014 11:36 AM
Rivets! newbusser Conversion General Discussions 4 05-01-2009 12:49 AM
Removing Rivets oldog12 Everything Else | General Skoolie Discussions 3 05-25-2007 10:45 AM
