Old 12-05-2007, 04:20 PM   #1
KC10Chief's Avatar
Rated Cap: 60
Removing rubber flooring
Well, I've been working on my bus today trying to get the rubber flooring up. It is glued down and is being a real PITA to get up. It is glued down. I can chisel it up in small chunks. Sometimes I get lucky and can peel up a bigger piece. I started in the back and am working my way forward. I've made it past the rear wheel wells, but I'm totally exhausted. Anybody got any better ideas on getting this stuff up? Thanks.
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
https://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 12-05-2007, 08:22 PM   #2
Chassis: All American RE
Engine: Cummins 8.3
Re: Removing rubber flooring
I haven't gotten to that stage yet but would a heat gun help any?
dentarthurdent is offline   Reply With Quote
Old 12-06-2007, 10:09 AM   #3
swinada's Avatar
Heat gun will help.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 12-06-2007, 10:41 AM   #4
phillbus914's Avatar
Mine came off very easy but I had plywood under the rubber. The wood under the rubber was water soaked and rotten so I'm sure that helped.
Maybe sharpen your chisel or power wash it off?
My Old Bus :(
Old 12-06-2007, 10:59 AM   #5
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
I also have a wooden floor. Taking off that rubber mat is really hard, I also had to chisel it off.
Take your time and maybe do something else when you get tired (make a pattern for the walls, make a roof deck, etc.).
Good luck with the floor.
Robert
Roasting8 is offline   Reply With Quote
Old 12-06-2007, 11:12 AM   #6
Buster's Avatar
Year: 1974
Chassis: Ford B-700
Engine: 351 windsor
In the past I have heated up a scraper blade with a propane torch to help cut through the glue. It works pretty good you just have to reheat the blade a lot.
Dave
Buster is offline   Reply With Quote
Old 12-06-2007, 03:00 PM   #7
lapeer20m's Avatar
why remove the rubber flooring??
Old 12-06-2007, 04:11 PM   #8
KC10Chief's Avatar
Rated Cap: 60
It was uneven. The aisle stuck up about 1/8" higher than the other rubber. I peeled up the aisle, and now it's about 1/8 lower than the other rubber. I probably could have laid my flooring across that, but I was paranoid that it would start to flex. I'm kind of anal like that. I have almost all of the rubber flooring up now.
Matt
7.3L diesel w/AT545
Old 12-07-2007, 10:08 AM   #9
Buster's Avatar
Year: 1974
Chassis: Ford B-700
Engine: 351 windsor
Were any of the suggestions helpful at all?
Dave
Old 12-08-2007, 07:22 AM   #10
swinada's Avatar
to get rid of the rubber smell.........and discover all the goodies below the rubber floor.
Remove rubber flooring. wmkbailey Conversion Tutorials and How-to's 11 11-27-2014 09:47 PM
Flooring & Sub Flooring Question QUIKSVT Conversion General Discussions 1 07-14-2012 09:11 AM
Any purpose in removing rubber floor Six Four Conversion General Discussions 4 02-24-2011 08:28 PM
Rubber floor recycler Conversion Tutorials and How-to's 2 06-08-2009 02:40 PM
Removing the Rubber Flooring--Good idea? Skoolie BOBB Conversion General Discussions 17 07-28-2005 10:08 PM
