Old 01-18-2005, 02:43 PM   #1
Removing the Rubber Flooring--Good idea?
The weather is warming up here in Utah, thanks to global warming, and I am getting back to working on my bus. What are the pro's and con's of the rubber flooring? I am going to put carpet in. I don't have rubber flooring in my house and I can't see why it would be an advantage in my bus. I'm on my first conversion and would like to have some input. Thanks.
Herb in Utah--1990 Blue Bird Flatnose
Skoolie BOBB is offline   Reply With Quote
Old 04-18-2005, 02:40 PM   #2
trx
trx's Avatar
Chassis: Chevy C-60
Engine: 8.2L Turbo Detroit Diesel
Send a message via ICQ to trx
You've probably already made your decision but I would remove it. Won't serve a purpose if you are carpeting, just adds more weight for no reason.
Chad
trx is offline   Reply With Quote
Old 04-19-2005, 12:30 PM   #3
Send a message via Yahoo to TravelingMan
I think it would act as a good moisture barrier if the floor is wood or partical board.
"I'm a man of means by no means King of the road"
TravelingMan is offline   Reply With Quote
Old 04-19-2005, 12:45 PM   #4
trx
trx's Avatar
Chassis: Chevy C-60
Mine seemed to do a good job of trapping moisure (over plywood). If there's a chance that moiture can get under it then you risk rotting the wood. Part of mine works good as a rubber mat in front of my workbench
Chad
Old 04-19-2005, 12:54 PM   #5
dammitAndy's Avatar
Engine: 370
Rated Cap: 44
I ripped mine out just to get the floor even. the center isle had metal running strips that stuck up from the floor about .25". I threw plywood and linoleum tiles down and i like how its working as far as sound and insulation...
'89 Ford 370-2V Wayne - Sold :(
http://www.dammitandy.com/bus
Plotting the next project now. Looking for a clean diesel pusher with low rust/miles. Identical plans with plumming and biodiesel added :)
dammitAndy is offline   Reply With Quote
Old 04-23-2005, 10:00 PM   #6
Hi,
I would not only recomend ripping up the rubber matt,but the whole wood floor. School buses sweat a lot and you would be suprised at the amount of rust that could be there.Ours wa rusted through the floor in some places and needed to be reinforced.~ Pixie
Enchanted Gypsy ~ Travel Diaries
http://www.enchantedgypsy.blogspot.com/
pixie is offline   Reply With Quote
Old 05-07-2005, 10:14 PM   #7
the rubber mat in mine did an excellent job of trapping moisture and rusting the floor!!!
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 07-05-2005, 03:54 PM   #8
Rubber floor removal
It took a while to get to it, but I removed the rubber flooring. What I found was damp plywood. That didn't seem too good. I also ripped out the wood and found that the metal floor wasn't really too rusty. I'll be replacing the wood in the next few days and start building this old bus up. And, yes I am glad I did it.
Herb in Utah
Old 07-15-2005, 11:04 PM   #9
Dan-O's Avatar
Just wondering.... what thickness of plywood are you/did you put down? I too am going to be ripping up the floor and putting carpet down, but I am wondering if I should just put it right over the steel?? (after paint of course) or should I put down 3/4" so I have something to screw into, or is 1/4" thick enough?
1990 Ford/Bluebird 16pass Shortie....
http://www.skoolie.net/gallery/Shortie
All right, brain, I don't like you and you don't like me - so let's just do this and I'll get back to killing you with beer. -- Homer Simpson
Dan-O is offline   Reply With Quote
Old 07-21-2005, 12:07 PM   #10
What we did was put 1x2"s the length of the bus ,then we put foam insulation in between,and a layer of 1'4 inch plywood on top.
We chose a tounge and groove wood floor,rather than carpet because of ease in cleaning-and looks.-Pixie
Is this transit bus a good idea? djDK Conversion General Discussions 33 03-22-2017 02:48 PM
Remove rubber flooring. wmkbailey Conversion Tutorials and How-to's 11 11-27-2014 09:47 PM
cat 3116 a good idea natertots Conversion General Discussions 11 08-25-2014 01:59 PM
Any purpose in removing rubber floor Six Four Conversion General Discussions 4 02-24-2011 08:28 PM
Removing rubber flooring KC10Chief Conversion General Discussions 9 12-08-2007 07:22 AM
