Old 10-13-2016, 07:05 PM   #1
warewolff's Avatar
Repairing International Instrument Cluster
Hi all,
Last time I took the bus out for a drive I noticed that the cluster was kicking in and out intermittently. Looks like most of the gauges are affected. I popped it out and grabbed my soldering kit to go through the board more carefully and clean it up, but I'm having trouble getting the main board itself out.
Photos...
Front of the instrument cluster after removing the plexiglass:
Rear of instrument cluster -- left and right boards have already been removed:
Close ups of the main board. Notice that I've already removed all the screws.
I peeled back some of the panels on the front and there is no access to the back of the board. Can anyone point me in the right direction? I've gently pried the board up with a screw driver but there is a lot of resistance and I'd prefer not to break it. How do I get this thing out so I can properly service it?
warewolff is offline   Reply With Quote
Old 10-13-2016, 07:12 PM   #2
when I repaired the one for DEV i had to pop the needles off of the gauges to gert the board out.. that one is also a 1991.. I have not done it yet to the new bus.. it is somethibng I'll tackle when I am back in ohio...
on the DEV the needles just popped off and pressed back on.. masybe there is a better way .. i also remembered where the needles were as on that 1991 panel the needles could be installed in any orientation so I was careful to put them back the way they belong.
Old 10-13-2016, 08:21 PM   #3
warewolff's Avatar
I just gave it another go after reading your comment and made a bit more progress on disassembly. Turns out you DON'T need to remove the needles (how did you put them back in the 'right' position again?). I hope I didn't foul anything up in the process..
There are 4 prongs for each gauge that attach through the board. There was no access to remove them from the front. I peeled back and tried to pry them out to no avail. Eventually I found that I was able to push out the prongs, one by one, from behind.
Using a small bit to pop them out, I went very slowly as not to put too much torque on the board itself. Hard to describe, but the photo should clear it up:
I then gently disconnected the "mileage" and "hours" wires. After removing all that I was able to free the main board:
Upon inspection I do see that some of the original solders are showing small cracks. I assume this is what is responsible for my issue. I'll post again when I complete the repair with some more photos.
A few more questions:
1) Is there a place I can find cheap LED replacement bulbs?
2) Is there anything else I should look for or inspect before putting this back together?
3) Cadillackid ... how did you verify that the "needles" were in the correct spot again?
Hope this helps someone in the future.
Old 10-13-2016, 09:37 PM   #4
Chassis: Genesis
https://www.superbrightleds.com/cat/...cluster-gauge/
Timelord is offline   Reply With Quote
Old 10-13-2016, 10:15 PM   #5
Year: 1994
This should be a permanent post. super good info
Geo Jeff is offline   Reply With Quote
Old 10-13-2016, 10:41 PM   #6
boojiewoojie's Avatar
Chassis: RE300
Engine: DT466E (250h.p.)
Rated Cap: 81
Yeah, you've went to a lot of trouble that you didn't need to do. I've repaired a good number of these and it's very simple: just renew the solder joints of the wiring clusters on the back of the board. 10 minute job. And if I remember correctly I THINK the LED lights are T5. Just buy the cheap ones off eBay.
Daddy, can we go on a trip again??
'85 Thomas SafTLiner RE
3208 NA CAT MT643
boojiewoojie is offline   Reply With Quote
Old 10-14-2016, 07:40 AM   #7
Ok that panel is a little different than the one in DEV... the one in DEV is a 1991... so looks like they made some changes...I didnt have the 4 prongs on each gauge... they were soldered to the board.... unless that is the "repair" previously made.. NOTED is the panel in DEV was not the original, it had a repair tag on it.. so perhaps it once had the glad to know I odnt need to pull the needles... because it was a PITA..
to get them back n, I powered the board up so everything Zeroed out.. fuel i knew was on Full and voltage i used a digital meter and matched it... air pressure i never disassembled as it is a mechanical gauge..
I wasnt sure the needles would stay on so I used a dab of superglue but maybe didnt need to...
mine came off very easily.. like I say it had a repair tag in it and appeared to have been soldered together.. i assumed they were all that way..
Old 10-14-2016, 01:33 PM   #8
warewolff's Avatar
Am I destroying this board? What technique am I missing?
Old 10-14-2016, 05:00 PM   #9
warewolff's Avatar
I just saw this! Thanks, Christopher. Didn't even think to power the board up first and re-align everything. Good tips on the fuel/charge gauges. That might be a little bit trickier. You took the measurements from the alternator with the volt meter?
In my last post I mentioned I might've been fouling things up -- I realized that both my solder and my iron are too large to tinker with the small circuitry. I was really making a mess of things. Recommendations on an appropriate iron/solder gauge or a kit that I can buy to finish this up correctly?
Lastly, has anyone swapped the mechanical gauges to electronic with success?
Thanks again Chris. You have saved me a lot of time.
Old 10-16-2016, 07:09 PM   #10
sorry i was on the road the last 2 days.. just getting to this.. drove the new bus from tampa to columbus ohio (its intermittent gauges and all)..
If im at my house I just have a cheapie radio shack soldering iron that i bought a finer tip for.. i realize RS is gone now.. so perhaps a hobby store is where i would try.. not a hobby lobby type but like an indeopendent shop where they deal with a lot of RC panes and cars.. they often have fine-tip soldering irons for working on that small stuff.. and usually reasonably priced..
ive got my Bus in columbus now so i can take that panel out and tear it apart to see hoe much different it was than DEV... I hope i didnt foul you up to much about disassembling the gauges themselves.. my guess is whoever originally rebuilt the one in DEV soldered the gauges right into the board.. or maybe it was that way... 1990 was the first year of that panel.. DEV is a 91..
I know on the T-444E based panel that some of the gauges get their info from the PCM.. at least thats how I read it in some of the service info..
I dont think IHC ever made that dashboard style with an electronic air gauge.. that was the only on DEV which was truly mechanical.... DEV is a mechanical engine.. but each gauge has a separate sending unit.. individual gauges flaked out randomly on that bus.. esp the speedometer.. till i resoldered it.
on my T-444E bus, it appears the fuel / amps / transmission temp are all electronic gauges but use separate sending units..
speed / volts / water temp / oil press / RPM are all data fed from the engine computer.. if those gauges all randomly freeze in their positions.. ie driving along and stop but your speedo and tach still read like you are rolling, thats just 1 wire thats typically fouled up... which is what my case is on the new bus.. they all work perfectly except they randomly freeze till i reach behind and gently press that connector..
even when my other gauges are frozen my fuel gauge still works... my amp gauge is flaky on its own.. I can reach behind and press on the second connector on that oiuter row and that gauge will function... my trans temp never works because the sensor on the trans is gone...
I'll try and take good pics when I take it apart.. ,maybe we can all share notes and come up woit ha nice sticky thread on how to fix these things.. because i know theres a lot of members with the same dash.. and my guess is a lot of them dont work right..
