Old 02-07-2010, 10:24 AM   #1
replacing engine, cherry picker strong enough?
for removing? putting in an engine he conventioanal cherry picker is probably not strong enough right? any ideas....how much do these things weighj?
adamanderr is offline   Reply With Quote
Old 02-07-2010, 04:46 PM   #2
GoneCamping's Avatar
Re: replacing engine, cherry picker strong enough?
What kind of engine are we talking about? If your bus is a gasser then a regular cherry picker will lift it, but may not be able to lift it high enough. If you are talking a big Detroit Diesel then it won't do it. Something in between like a 5.9 Cummins or something like it MIGHT work...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 02-08-2010, 10:01 AM   #3
have a bunch of buses. wanted to take the ihc FE 9.0diesel out of the 30 footer and put it in the FEmini bluebird. then put a dt466 into my 30 footer. trans not attatched. how do they usually do it forklift? definitely dont have access to one of those. also looking for a cummmins 5.9 to put in my breadtruck, vintage gerstanlager bookmobile, any suggestions on finding one of those. thanks off line at215-350-7209
Fast drying but strong adhesive? Diesel Dan Conversion General Discussions 2 07-30-2010 12:12 AM
replacing the floor. Why? tfdfyrman Conversion General Discussions 2 06-05-2009 12:52 PM
replacing the alternator adamanderr Conversion General Discussions 2 04-20-2008 09:16 PM
Replacing air hoses dlor1 Everything Else | General Skoolie Discussions 1 04-15-2008 11:42 AM
Replacing Gas engine with Diesel engine question ? soused moose Conversion General Discussions 7 03-17-2005 08:15 PM
