Old 07-06-2019, 02:26 PM   #1
Replacing rear lights
I'm converting a 2004 Ford e450 collins bus. It was bought from an auction -- the rear lights (break light, turn signal, etc) were removed. The wiring is still running to them, though I was told the fuses were removed. My plan is to keep the bus stationary where I live, but I want it in decent running shape in case I ever move to a different property or sell the bus. It's not a huge deal if there's no lights, but if it's easy to fix, now's the time before I insulate and cover up that area.
Ideally I'd do the cheapest, simplest fix that works okay. I don't know anything about this sort of thing. Can I buy cheap generic light sockets and jerry-rig them to stay in place? Do I need to match any sort of electrical voltage / amperage amounts with the bus? How would I find out those sorts of things?
Thanks
ForestGarden is offline   Reply With Quote
Old 07-06-2019, 02:51 PM   #2
HazMatt's Avatar
Chassis: IH 3800, 8 window
If the wiring harness is intact, then there should be no problem in replacing the fuses and light fixtures.
I'd recommend looking for a similar bus that's being parted out for the housings, sockets (maybe even bulbs!), and lenses. They can also be had new from a dealer or online, at a substantial cost increase.
It will be much easier to do this pre-insulating, tho I'd caution you not to insulate right up to the light housings, due to a potential fire hazard.
Sockets & lenses alone would barely work, they need a reflector behind the bulb.
Everything should be 12V DC, so no worries there. As to what the correct fuses and bulbs are, I'd suggest you flex your Goo-Fu for the info, &/or call the manufacturer or a dealer.
PS: If you input your bus' specifications into your profile, you won't need to type that info in again. Nobody'll be able to offer an assist without all those fields filled in.
Old 07-06-2019, 03:10 PM   #3
https://www.amazon.com/slp/truck-tai...h9yyy6euq2b6b5
