Old 04-07-2008, 06:56 PM   #1
replacing the alternator
I feel i'm having charging problems. so i want to replace batterries, leads, terminals and wiring to alternator....and to replace the alternator. i have a 1985 leech neville 14v 105amp. any insight or is there anything i should know or look for in a replacement.. just a straight repalcement.....or more power etc.
thanks
adamanderr is offline   Reply With Quote
Old 04-07-2008, 08:44 PM   #2
lapeer20m's Avatar
Re: replacing the alternator
105 is about the smallest amperage version of that alternator. It's easy to find a new alternator,,,ebay has them really cheap. The leece neville is very common on big trucks and buses. Some only require 1 wire, while others require 2. IF you're bus is set up for 2 wires currently then it makes no difference which alternator you end up with. You're local alternator shop can rebuild the one you have, but i've found that ebay is a cheaper solution, if you're not in a hurry.
I like more power from my alternators....165 amps is a good amount....i think they offer all the way up to like 300 amps, but that's getting a little silly. What size aternator you want depends on what kind of electrical loads you're gonna have. I like to have a 2kw inverter, so bigger alternator is better. Running the 5 standard blowers for heat/defrosters in a bus, plus the stock headlights is gonna require most of that 105 amps.
swapping the alternator is a very straightfoward process. might as well buy a new high quality belt for the alternator/water pump while you have the hood up.
Old 04-20-2008, 09:16 PM   #3
Ohio Josh's Avatar
Year: 1982
Chassis: Chevrolet
Engine: 8.2L fuel pincher
Rated Cap: 60
Great info!
Ohio Josh is offline   Reply With Quote
Replacing the front door Zephod_beeblebrox2 Conversion General Discussions 13 09-14-2022 11:19 AM
replacing 8d starting batteries gbstewart Electrical, Charging and Solar 11 05-09-2014 10:48 PM
Replacing A Leaky Bus Window lornaschinske Conversion General Discussions 3 08-15-2012 06:32 PM
replacing the floor. Why? tfdfyrman Conversion General Discussions 2 06-05-2009 12:52 PM
Replacing air hoses dlor1 Everything Else | General Skoolie Discussions 1 04-15-2008 11:42 AM
