Old 06-09-2013, 04:48 PM   #1
jkronmiller's Avatar
Chassis: IH
Engine: 444E
Replacing the door with ext house door?
Greetings! I am looking for some insight as to the best way to replace the standard mechanical entry/exit doors on a school bus. I know from talking to the local contractor store that I need a 30" pre-hung which will give me a half inch on both sides to trim it out. However the doors are all too short. What have others of you that have replaced the original with a house type door done? Any ideas would be appreciated! Thanks!
jkronmiller is offline   Reply With Quote
Old 06-09-2013, 10:21 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Replacing the door with ext house door?
The height problem was part of the reason why we turned our two piece bifold bus door into a one piece single hinge swing door. The main reason was we could rebuild the original door as opposed to buying a special ordered door or custom building a new door. We are converting on a skinny wornout shoestring budget. Not everyone is converting to the extent we are on as tight a budget.
Fulltime since 2006
Old 06-10-2013, 02:05 PM   #3
Chassis: Blue Bird
Engine: ISC 8.3
Frayed ends too, where the plastic shrink-wrap has crumbled away? That's a wonderful chain of adjectives and draws a great mental image. I love it.
There are a few folks here whose build threads show home-made doors. One I'm thinking of is constructed from some square steel tube, maybe 1" by .060" wall, with a skin welded to it and a nice window. IIRC they used standard residential lock hardware. It looked really good and for cost it must fall somewhere between shiny new pre-hung and recycling/modifying the original door. Modifying the original has some upsides if you're not real handy with welding yet or just don't want to fuss with it. You'll be assured that the door will fit the opening just right!
I'll probably end up going the square-tube custom route on mine. I have a transit style double door: two panels each hinged at the outside edges and they swing outward from the center. This style, not having a piano hinge up the middle that I could make rigid, doesn't lend itself to re-use very well.
If you want to go with the exterior residential door, those can be had in (somewhat) custom sizes. Economics of it depend heavily on whether you're in or near an urban area where there are windows-and-doors vendors nearby so you don't have to pay shipping. I've had a few made and the cost increase wasn't much, but I did pick from a collection of standard-sized door slabs and customized only the jambs and thresholds.
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 02:54 PM
Replacing the front door Zephod_beeblebrox2 Conversion General Discussions 11 10-27-2014 10:30 PM
Replacing bus door with storm door??? leadsled01 Short-Bus Conversion Projects 13 03-18-2014 07:31 AM
Side door/ Rear door SeanF Conversion General Discussions 6 05-24-2009 11:56 AM
Anyone ever used the bifold door as camper door ? RichardRWatson Conversion General Discussions 6 07-04-2007 09:27 PM
