Old 10-09-2014, 11:13 PM   #1
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Replacing the front door
I'm looking into buying a 1998 Carpenter bus at the moment. 5.9L diesel engine, automatic transmission, 98K miles.
It's already been converted into a hunting lodge but lacks any insulation whatsoever and still has all the windows and the original doors.
I'm planning on replacing the glass with steel and replacing the concertina door with a real door. Any ideas on how to do that and where to get the door/parts? I don't have a machine shop, sadly so things have to be easy to adjust.
I'm going to have to do insulation but that's another topic.
Zephod_beeblebrox2 is offline   Reply With Quote
Old 10-10-2014, 05:08 AM   #2
Re: Replacing the front door
most folks either
1)keep door factory
2)make door 1pc non folding using a few pcs of metal and original hinge
3)frame out like a house (bolt wood to bus, and use a house door
pick your poison, plenty of pics here
Old 10-10-2014, 06:23 AM   #3
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
4) Go to the local Rv supplier and buy a door kit.
Ponyracer is offline   Reply With Quote
Old 10-10-2014, 10:22 AM   #4
Year: 1994
Engine: 466dt
Rated Cap: 59
Interesting ideas.
With the door hinges, I'm concerned that somebody might be able to knock the pins out and simply lift the door off its hinges to gain access. Are there any hinges such as those in car doors that can't be accessed from the outside?
I'm all new to this as you can gather from my beginner questions.
Old 10-10-2014, 11:11 AM   #5
r_w
Pins can be welded into the hinge. Car door style hinges can be made ($$$$$$$$)
But you have a whole bunch of windows people can break to get in if they want. anything you do to the door only keeps honest people honest.
I am more worried about a door that seals properly to keep the weather out than one that locks to keep intruders out.
r_w is offline   Reply With Quote
Old 10-10-2014, 12:27 PM   #6
Year: 1994
Engine: 466dt
Rated Cap: 59
You're right. As far as security goes - even a big thing like a bus can be jacked up and lifted onto a dolly then towed away.
I'm with you regarding keeping the weather out.
I had a look at one guy's method of turning the concertina door into a solid door.
Has anybody tried just using the back door to get in and out and putting a sliding "deadbolt" bar across the inside of the concertina door? Obviously the bar would have to be round with a rotating steel sleeve around it (to defeat the bright spark that things they can use a power saw to cut through the bolt.
Old 10-10-2014, 12:30 PM   #7
we "lock" our front door when we leave for the day and at night
We then use the back down as entry/exit until front is "un-locked"
no pictures, it's too ghetto and way down on list to fix
Old 10-10-2014, 12:57 PM   #8
r_w
There are so many variations in doors--open in the middle, hinge in the middle, open in, open out, manual, air, electric. There isn't a one-size-fits-all.
Simple crossbar barricade arm works in many manual doors but could destroy an auto opener. Deadbolts or garage door locks going up and down work. The surface mount locks (same as is usually used for back door) work for some. You can get factory option locks for some buses.
The old activity buses we had had what looked like an old garage door latch mounted just above the mirror mount in the corner of the pillar. It had a shaft that went to the manual opener and popped it open.
Old 10-10-2014, 01:11 PM   #9
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Drop in doors for RV's are simple, just adjust your opening and rivet it in.
As far as hinges, you can spot weld the pin in place, also they make higher security hinges that are pressed together, the pin can't be knocked out.
I wouldn't really worry about the hinges if you use a house door, more than likely anyone who wants into a converted schoolbus will be an amateur thief and will prob just break a window.
If you want to SECURE it, for instance if it will be alone on a remote hunting property, install 16 gauge "hurricane shutters" with a top piano hinge and a bottom hi security hasp and padlock, same for the door, just use a metal security door or a piece of sheet with side hinges.
Old 10-10-2014, 04:11 PM   #10
lornaschinske's Avatar
Rated Cap: 89
We turned our two piece door into a one piece door. http://www.freewebs.com/aluminumasylum/bluebirdfe.htm
Since I posted all that, we have replaced the door handle with a lever style. Changed the weather stripping to a thinner one will allows the door to latch. We will need to finish trimming the interior and add the accordian door we will be using to keep the cold down from all that glass. It works for us and isn't for everyone.
Fulltime since 2006
Old 10-26-2014, 05:46 PM   #11
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
I am following this thread. I currently have a RV door but the hinge pins are bent and not really sure if I want to go through the pains of messing with it.
All the RV door kits I have seen are DEATHLY expensive. To me 400-500 dollars for a RV door is not really an option. As I have stated before I have the hardest time finding parts rvs in my area. They seem to be made of gold here in DFW.
I would like to put a house hold metal exterior. Nothing fancy just straight boring flat metal. I would like to cut in a inset glass with a blind that can be raised and lowered when needed and opened and closed like you have on mini blind in your house. Probably to the safest thing int he world but I can reinforce a pull down metal slide on the inside to to deter this.
So if you have any ideas on this please share. I am also willing to make my own door is someone has a step by step process?
Not opposed to wood just prefer metal if given a choice
Old 10-27-2014, 11:30 PM   #12
roach711's Avatar
Rated Cap: 19
We replaced ours with an Anderson security storm door. It has laminated glass, a full length hinge and a three point latch with a key lock. It's 2 years old now and aside from a few squeaks it's been solid.
The Roach Motel
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 03:54 PM
Replacing bus door with storm door??? leadsled01 Short-Bus Conversion Projects 13 03-18-2014 08:31 AM
Replacing the door with ext house door? jkronmiller Conversion General Discussions 2 06-10-2013 03:05 PM
NEED front door hinges millertyme Classifieds | Buy, Sell, Swap 1 09-20-2009 12:43 PM
Bus front door question soused moose Conversion General Discussions 3 04-22-2004 09:32 PM
