Old 01-29-2017, 07:20 PM   #1
Replacing top flashing lights
Hey, i have a shortbus and i took the top lights out and have to put something in their place, does anyone have any advice? I was thinking of laminating vinyls and putting them in place of the lights. Id love to hear suggestions
Sent from my iPad using Tapatalk
instantbmx is offline   Reply With Quote
Old 01-29-2017, 08:29 PM   #2
Hello. I am new to this site looking for answers. I have a 2001 ford e450 champion bus that has a couple of issues in the fuse box located above the drivers head. The wire connector that goes to the fuse box and the wires run to the rear heater relay got so hot that it melted the plastic and it blew the fuse. I replaced it and then touched the connector it was extremely hot. The rear heater did work though but the new connector got really hot again. What do you think this is?
Pstone is offline   Reply With Quote
Old 01-29-2017, 08:46 PM   #3
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Originally Posted by Pstone View Post
Hello. I am new to this site looking for answers. ...
PStone - welcome! But you ought to start with a new thread: as it is, folks will not see your question because it is buried under a 'flashing lights' post. Wishing you the best!
Dapplecreek is offline   Reply With Quote
Old 01-29-2017, 09:49 PM   #4
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
I deleted my front flashers by cutting a piece of aluminum that fits over the entire front roof cap, then attaching it with 3M 5200 marine adhesive. When it's painted body color it will look like it came from the factory that way. I just don't like seeing obvious patches over each light. It's more work to do it this way, but I think it will be worth it.
I repurposed my rear flashers as extra high-mount brake lights. They only work when I turn on my fog lights, and together with a Hella red rear fog light I should be very visible in fog or heavy rain.
PS - you posted this thread three times!
Old 01-29-2017, 10:35 PM   #5
roach711's Avatar
Rated Cap: 19
Most just use sheet metal to block off the holes but it would be cool to mount rocket launchers or machine guns at each corner.
The Roach Motel
Old 01-30-2017, 07:41 AM   #6
ourmefa's Avatar
I am planning to replace the lights in mine with clear lens for one set (with superbright LED flood), and rewire as turn signals for the second set (if there are two). There are some good resources in this thread for where to get the lenses - http://www.skoolie.net/forums/f10/fl...html#post45071
Family of 4 - Jamie, Mel, Jensen and Maddie (+3 cats) - less than 60 days out from ditching suburbia in a converted school bus.
Find us on Facebook-Affiliate Link Disclaimer
ourmefa is offline   Reply With Quote
Old 01-30-2017, 10:04 AM   #7
Been a lot of discussion on converting the upper fronts to white lights. Consensus seemed to be that DOT limits the height on any forward facing white lights to less that what a skoolie is and/or require they be covered when on any public roads. Fine for off road but can be problem otherwise.
Anyone else recall this discussion/thread?
Old 01-30-2017, 10:10 AM   #8
Justin McCormick's Avatar
Chassis: Saf-T-Liner MVP ER
Engine: Cummins 5.9L Diesel Engine
Rated Cap: 83
I replaced mine with LED lights. Here is a couple video about how I did the lights:
And then more details about the wiring:
Follow our bus blog here -
http://www.wildernesswandering.com/
Justin McCormick is offline   Reply With Quote
Old 01-30-2017, 10:40 AM   #9
Engine: Navistar 7.6L
I have never found a Federal nor State D.O.T. regulation regarding the requirement to keep forward facing "white lights" (other than the o.e.m. headlights) covered to be legal on-road.
You just can't turn them on when on-road.
DoubleO7 is offline   Reply With Quote
Old 01-30-2017, 10:44 AM   #10
ourmefa's Avatar
This was my understanding as well. I ask the TN DOT guy about it and he said you can have whatever lights you want on the bus, you just cannot have them on except for the normal legal stuff - marker lights, front and rear turn/running lights and headlights.
