08-12-2015, 02:07 PM
Reuse Interior Panels?
Newbie question--I have searched, but can't find anything about this so far. When I search on "reuse panels," most of the threads I get are about solar panels or other panels. And I've scrolled through numerous build threads and such trying to find this, but no luck.
Anyway, here is my question: Can you reuse the interior wall panels of the bus to cover window holes? I see most people use sheet metal, but why can't the metal they already have be used in this way? Is it a different kind of metal, or does it usually just get torn up in the removal process?
Thanks.
I-Cat
08-12-2015, 02:56 PM
Thanks.
I read somewhere that you can just don't remember where
08-12-2015, 04:01 PM
The texture looks unappealing. Thats the only reason I scrapped mine. I actually have some stored for.use, just not sure what to use em for something not visible...
08-12-2015, 06:01 PM
I intend on doing just that. It appears I will have enough to cover all the windows I intend to cover (about half of them). That is, if I do not do a roof raise. My panels, once removed laid perfectly flat, and I've since leaned them up against my fence for storage and they are still staying nice and straight.
-Travis
1991 International. DT360. Spicer 5-speed manual transmission. Work in progress; spray foam, wood stove, etc...
08-13-2015, 12:12 AM
Mic the metal to determine the gauge. If it is consistent with the rest of the body work, you will be fine.
Free=Good.
08-13-2015, 12:57 AM
Engine: 190hp 5.9 Cummins
I used the interior ceiling panels to cover the windows in my shed build. I had them sheared to size on a 12 foot shear, then installed with screws.
The shed build is in some of the last pages of this build.
http://www.pirate4x4.com/forum/tow-r...-haul-all.html
Keep in mind many of the panels will have holes from interior lights, speakers, ect.
If they have a hole, just rivet another piece of steel over it.
08-13-2015, 10:31 PM
Hooray! That is awesome. If I'm going to be able to do this, I need to keep costs down, down, down, but I still want decent quality. It's good to know it's possible. Thanks.
I-Cat
