The insulation would have to actively slide across the top of the bedliner product. It seems like the rough surface would prevent the insulation from sliding around. I mean if we're talking about the same thing there's going to be some weight on the flooring surface over the insulation. Even with a floating floor installation I cant imagine the insulation sliding around, but I'm no expert in insulation or construction for that matter.
On my first bus I put Blackjack roof repair on my badly rusted steel subfloor using a large tile comb before covering with 3/4 ply. It actually worked well and didn't smell even in the summers. It was the window design on that first bus that rotted out the floor originally. It's been about 30 years and it's rotted out again, but I'm guessing that coating of tar on the floor is still keeping that steel subfloor from rusting.
It works similar to one of those vibrating sanders. With a lot of weight on it, or everything screwed/bolted down to it, it may not be an issue.
Originally Posted by o1marc
I plan on glueing down the rigid isolation, so I doubt it's going to be moving and sanding itself down.
The few that I have done, I have only glued down the foam and ply. I do add some screws if I go with thin ply like 3/8 or 7/16. Everything framed on top of the floor should hold it down.
