Old 11-23-2015, 02:01 PM   #1
Coachwork: AmTran (International)
Chassis: Gensis
Rated Cap: 74
Rigid Foam Adhesive
What is the best caulk type adhesive for gluing rigid foam to the metal bus?
slager55 is offline   Reply With Quote
Old 11-23-2015, 02:40 PM   #2
roach711's Avatar
Rated Cap: 19
I used the poly-iso foam boards with a blue plastic coating on one side and a foil coating on the other. The Liquid Nails folks said I should use Liquid Nails for Marble and Granite and it worked real well on my build.
Old 11-24-2015, 04:54 AM   #3
ElizaHasAPlan's Avatar
I find this site helpful for these kinds of questions:
This to That (Glue Advice)
It's never failed me
ElizaHasAPlan is offline   Reply With Quote
Old 11-24-2015, 11:57 AM   #4
roach711's Avatar
Rated Cap: 19
Here's mine with the flooring and insulation in. One thing I should have done was to seal the gaps between panels and around the windows to keep humidity from getting behind the panels. We haven't had a problem with it so far but we also don't produce much humidity either. I had to prop the panels against the walls and ceiling so the adhesive could cure overnight.
Detail of the floor
