Old 04-27-2007, 07:55 AM   #1
rims
Hello folks, new to this site and have found lots of helpful info here already. I have a 84 gmc-thomas bodied bus. The bus has 6 lug split rims. Is there a solid rim out there to replace these with?
odee is offline   Reply With Quote
Old 04-27-2007, 09:27 AM   #2
sportyrick's Avatar
Chassis: F33695
rims
You are going to have to elaborate a little more on what kind of rim you have, Bud or Dayton? What size tire, 20, 22.5, 24.5, 19.5? sportyrick
Old 04-27-2007, 02:08 PM   #3
the_experience03's Avatar
It SOUNDS like you have Daytons. If you currently have 10.00-20 tube tires a set of 11R22.5 tubeless rims should bolt right on no problem and will give you the same overall diameter as you have now. I was quoted about $100 per rim new and tires run the gamut.
If your current tires are small, say 9.00-20 you will have to be a little more careful about spacing and clearances, but you shouldn't have any problems. Any reputable commercial tire shop should be able to help you figure it out.
Old 04-27-2007, 04:04 PM   #4
sorry guys got ahead of my self this morning trying yo get out the door to find an answer. The buss has 8.25x20 budd style 6 lug rims. I would consider changing the front rotors out if I have to for some 10 lug ones if they make them. My wheels now have the ring that comes off.
Old 04-27-2007, 04:09 PM   #5
Steve's Avatar
That is exactly what my bus had (8.25x20 budd 6-lugs). I replaced them with 6.75x22.5 6-lugs and put on 10R22.5 tires.
I only found one company that sold solid wheels with that bolt pattern and they were expensive!
Old 05-01-2007, 10:19 PM   #6
anybody else with input on the rim swap or possible hub swap? Different front axle?
Old 05-02-2007, 12:31 AM   #7
Steve's Avatar
I bought my wheels from Midwest Wheel and they were $145.57 each. I don't know who made them but you can call them at 515-265-1491
Old 05-02-2007, 12:38 AM   #8
The axle and hubs aren't likely going to be the issue. Chances are you're going to have the same mounting pattern on a new axle unless you have smaller rims right now. Even then...Steve managed to get something going on his bus with the smaller rims. When you start talking about axle and hub swaps you're talking about brake swaps too which must be matched to the rest of the system, steering, blah blah blah.....I would just talk to your local commercial tire place and see what they tell you.
Old 05-02-2007, 05:09 PM   #9
thanks guys I have found out that gm made a 10 lug hub and rotor that will fit my spindle on the front axle. Now just got to find them or a whole axle. I will give the folks a call about the wheels. Way cheaper than the ones I priced here.
Old 05-02-2007, 05:16 PM   #10
Where do the 10 lug hubs leave you on the back axle? Still boned? What about the brakes? I'm a little curious as to this set up now.
Old 05-03-2007, 10:19 PM   #11
from what I have been told the hubs will just swap out on the front. same brakes will work. The rear I haven't asked about yet, but it should be like the front. I want to find a way around the rims to use something that is able to be found easy in case of a bent rim or such on the road.
What colour to paint rims? lornaschinske Conversion General Discussions 174 03-26-2015 02:54 PM
Split Wheel Rims... TygerCub Conversion General Discussions 3 06-13-2009 08:59 PM
6-lug rims odee Classifieds | Buy, Sell, Swap 0 10-26-2008 06:16 PM
Dayton Rims colliervilledave Conversion General Discussions 4 03-28-2008 12:02 AM
Dayton Rims colliervilledave Conversion General Discussions 2 01-11-2008 06:16 PM
