Old 06-06-2019, 05:22 PM   #21
5.3 cfm isn't much air flow so I'm not surprised. Two thoughts. First, try someone else's chisel and second, try someone else's 10 cfm air supply--or both.
Old 06-06-2019, 07:33 PM   #22
Originally Posted by Thetireddad View Post
Hey guys I got s much bigger compressor and I jacked the regulator way up and it’s still not doing anything...even poking the centers in....any ideas? It’s a 20 gal 5.3 cfm and in any fashion I can’t get s damn rivet out
Post a video of yourself using it and I'm sure somebody here will figure out what's happening. I got my non-starting bus diagnosed here that way.
Old 06-06-2019, 07:41 PM   #23
DawgBüs's Avatar
Year: 1982
Coachwork: Ford
Chassis: E-350; 4x4 Minibus
Engine: 351c.i.
This isn't meant to talk down to you in any way, I just don't know how else to phrase it, but... Are you sure you have the air chisel set up right? I added a quick release to mine that threads onto the end of the gun. It has set screws around the edges to prevent it from backing out but, they're useless. If it even backs out a 1/8 turn, I lose all cutting power. It still makes the same sounds as if it's working as its meant to. I just can't get through rivets, even the aluminum ones. If I hadn't used one before I might not recognize there's a problem.
Some will have a "power" screw to adjust the gun's speed/force. If that gets out of whack, same deal. Might be something to look at.
Pictures might help us or even a short video clip. I'm wondering if you don't have some solid rivets in there or if your chisel/technique is off or...?
-Travis & the DawgBüs
<<1982 E-350 cutaway, Collins Bantam ext. body, Maximum 4x4 F-350 drivetrain conversion>>
DawgBüs is offline   Reply With Quote
Old 06-06-2019, 07:45 PM   #24
My very first day working on my bus, the sum total of my accomplishments was two faint scratch marks on a single chair bolt in the back. Turns out I kept putting the blade in the grinder backwards. In my defense, I'd never used an angle grinder before and it doesn't actually say anywhere on the ******* packaging (for the grinder or the blades) how you put them on.
Old 06-06-2019, 08:00 PM   #25
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
How sharp is your chisel? I periodically sharpened mine and it would go through aluminum rivets in a fraction of second (after punching out the mandrel) and steel in a few seconds. I was running 120 psi for the air.
Ted
chisel, removal, rivet, rivet help, walls
