Old 06-05-2019, 10:45 AM   #1
Coachwork: international
Chassis: Front engine
Engine: mechanical DT466
Rated Cap: 71+
River hell
Ok so Im just getting started on the wall rivets. I have the air hammer with center punch to punch out the holes.
1. Almost none of the holes are punching out
2. When I am using the forked chisels(sharpened and unsharpened) they dont come close to budging the rivets. My gun goes up to 90psi and it appears to be functioning properly.
What the hell do I do? Angle grind the 1000 rivets off? Any ideas
Thetireddad is offline   Reply With Quote
Old 06-05-2019, 10:48 AM   #2
Chassis: G30
Engine: 350 Chevy
Rated Cap: 10K
Drill maybe?
Old 06-05-2019, 11:00 AM   #3
I had the same problem until I anted up for a BIG compressor capable of delivering 120 pounds of air at 10 CFM on an ongoing basis. Air chisels need a huge volume of air to really get the job done. To help with your immediate problem try grinding a "cross" into the head of the rivet using thin blade disc grinder before you go after it with the chisel.
Old 06-05-2019, 11:20 AM   #4
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
Sometimes you got to grind the center punch down. Same size as rivet hole
Nick
Old 06-05-2019, 11:24 AM   #5
Mistyped Title,
Old 06-05-2019, 11:27 AM   #6
A center punch has a point already smaller than the mandrel on a rivet. Don't know what the OP's issue is, shouldn't be that hard to pop the mandrels out.
Old 06-05-2019, 11:27 AM   #7
Ninjakitty's Avatar
I had to grind mine down about a half an inch to pop mine out
Nick
Old 06-05-2019, 11:41 AM   #8
DawgBs's Avatar
Year: 1982
Coachwork: Ford
Chassis: E-350; 4x4 Minibus
Engine: 351c.i.
Are you hitting the rivets with the fork chisel on the head side of the rivet? A lot of mine were aluminum (big plus) but even the steel ones I didn't need to punch the centers except on four of them. The rest, with sharp/radiused chisel, I could zip through in about 5 seconds each. Place the edge of the chisel just beneath the lip on the rivet, place a slight pressure on the air gun as if you're trying to pry up the rivet, but nowhere near enough pressure to actually do so, as you pull trigger. Should chew through the mandrel with little effort. Sometimes I had to switch directions after cutting halfway into the mandrel but most went easy, one pass.
-Travis & the DawgBs
<<1982 E-350 cutaway, Collins Bantam ext. body, Maximum 4x4 F-350 drivetrain conversion>>
DawgBs is offline   Reply With Quote
Old 06-05-2019, 12:15 PM   #9
Rated Cap: 71+
Is my compressor just too weak? My air hammer says to run at 90 psi but Im using it at 125( until it drops down 2 secs after)
File Type: jpg DA3F401A-2999-4455-ADEA-E86B4F2EB8D7.jpg (227.2 KB, 6 views)
Old 06-05-2019, 12:26 PM   #10
DawgBs's Avatar
Year: 1982
Coachwork: Ford
Engine: 351c.i.
I used a 10gal capacity and when I bought the harbor Freight gun it said 11 gal was the minimum to run an air chisel gun. My 10 gal definitely had to work double duty. You might try a bigger compressor for sure, if one is available. They push a lot of air pretty quickly.
chisel, removal, rivet, rivet help, walls
