Old 04-17-2009, 01:27 PM   #1
newbusser's Avatar
Year: 90
Coachwork: blue bird
Engine: Navistar Straight 6 Turbo
Rivets!
Before I bought a bus, I really kindof liked rivets....now I absolutely hate the sight of them!!! What kind of sadist was in charge when they decided to put a rivet every inch and a half down both sides of the bus interior........top and bottom?
One way to make it a LITTLE easier, look into the hole on each rivet. If the center metal piece (the one that draws back to expand and break off) is still there, take a center punch or small straight round punch and knock the center piece out. After you do this, drilling out with 1/4 inch drill bit is a lot easier.
“Twenty years from now you will be more disappointed by the
things that you didn't do than by the ones you did do. So throw off
the bowlines. Sail away from the safe harbor. Catch the trade winds
in your sails. Explore. Dream. Discover." Mark Twain
newbusser is offline   Reply With Quote
Old 04-17-2009, 02:08 PM   #2
Papabear's Avatar
Coachwork: ward
Chassis: IH
Re: Rivets!
And you will never like them again, although you will install a few.
On my bus, some were steel, some aluminum, some flattened on the back, some with holes, some without, and some that were installed by Satan himself
I tried the punch it/drill it method. It was easier for me to just grind them off (the steel ones anyway) A 4 1/2" side grinder makes pretty quick work of them. Good luck
"I've never been lost, but I been mighty confused for several days"
Papabear is offline   Reply With Quote
Old 04-17-2009, 07:12 PM   #3
Re: Rivets!
when you're buying replacement rivits, mke sure that they have the steel mandrelss/nails so that you can pull them up tight.
for removal, get several pin punches of the appropriate sizeand shorten the pins to bout 1/2 inch so they dont bend and get stuck in the holes. clamp one in a pair of visegrips, grab a 32oz hammer and go get your frustrations out. you can buy 9/64" double ended drillbits by the 10 or 12 pack envelope the perfect size for 1/8 rivets and also pilot holes in up to 1/4" steel, drill the rivet heads until you can't get any more on the drillbit then grab them with pliers and reverse the drill to remove them.
Old 04-29-2009, 10:10 AM   #4
Coachwork: genesis
Chassis: international harvester
Re: Rivets!
for drilling 1/8" rivets I've found a #30 drill bit is the correct size & using cobalt drill bits will drill many more steel rivets than high speed steel bits ever will, also #30 drill bits are the size of clecos, which clecos you can find at the " yard store" they have a web site, don't forget to get cleco pliers also. Have fun.
dieselman69 is offline   Reply With Quote
Old 05-01-2009, 12:49 AM   #5
newbusser's Avatar
Year: 90
Re: Rivets!
yes, I gave up on the drill and cuss method. 4 1/2 inch grinder with a supply of harbor freight grinding wheels works wonders. Just have to watch the heat.
Rivets Zephod_beeblebrox2 Conversion General Discussions 4 10-15-2014 11:36 AM
Screws Instead of Rivets? rex_1_mn Conversion General Discussions 3 12-22-2012 10:23 AM
Air riveter and 1,000 rivets Abbott Classifieds | Buy, Sell, Swap 2 05-11-2010 01:37 PM
Removing Rivets oldog12 Everything Else | General Skoolie Discussions 3 05-25-2007 10:45 AM
Bus type rivets hoser Conversion General Discussions 0 04-03-2006 04:55 AM
