Old 10-14-2014, 08:58 PM   #1
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Rivets
I'm struggling to find waterproof rivets like they use to rivet the body together. Is there any common source or do I have to order from China.
What I'm planning to do is to remove some of the windows and rivet some 20ga steel over the holes with some epoxy glue around the edges to ensure a seal. Now I know the bus will flex but I'm hoping it won't flex that much.
Zephod_beeblebrox2 is offline   Reply With Quote
Old 10-14-2014, 09:19 PM   #2
Chassis: Genesis
Re: Rivets
https://www.fastenal.com/web/products/f ... ivets%22|~
Timelord is offline   Reply With Quote
Old 10-14-2014, 10:24 PM   #3
Year: 1994
Engine: 466dt
Rated Cap: 59
Re: Rivets
Ahh.... And there's a branch not ten miles from my house too!
Old 10-15-2014, 02:07 AM   #4
Chassis: Genesis
Re: Rivets
Glad it worked out.
Old 10-15-2014, 11:36 AM   #5
Year: 1994
Engine: 466dt
Rated Cap: 59
Re: Rivets
Yup. Thanks. Now I have to get the pesky bus purchased. Buying it from out of state and it has a different state's license plate and an expired tag.
Hoping the guy has tole oil leak fixed and the bad tyres replaced at least with part-worn.
I must admit I *Like* this bus.
The plan is to remove the majority of the side windows and to put steel sheets over them, riveting the sheets. I'll probably also put some glue behind the sheets to ensure a water-tight seal. The rivets will be coated in glue also as well as being closed-end rivets. I've been thinking about the kind of glue to use and what with reading elsewhere on this site about torsional twisting of the bus as it hits potholes etc, I suspect I might instead of using an epoxy glue that sets hard, using a rubber-based glue that has some flexibility. Needless to say, the sheet steel will be painted both sides and in the holes and edges before it's installed. I hate rust.
Screws Instead of Rivets? rex_1_mn Conversion General Discussions 3 12-22-2012 10:23 AM
Air riveter and 1,000 rivets Abbott Classifieds | Buy, Sell, Swap 2 05-11-2010 01:37 PM
Rivets! newbusser Conversion General Discussions 4 05-01-2009 12:49 AM
Removing Rivets oldog12 Everything Else | General Skoolie Discussions 3 05-25-2007 10:45 AM
Bus type rivets hoser Conversion General Discussions 0 04-03-2006 04:55 AM
