Old 01-05-2015, 05:16 AM   #11
Coachwork: corbiel
Chassis: Ford E350
Engine: 7.3
Rated Cap: 10 people&handicap
No reason why it should not work. My dad put one in the side of his small garden shed that was only about 6 or so feet high, . I could check with him where he got it. very light weight.
woodsong is offline   Reply With Quote
Old 01-12-2015, 05:09 PM   #12
RevBill's Avatar
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
.. check out the ones used on rescue vehicles/firetrucks (can be pricey) .. fair warning though, they are not insulated nor weather-proof/water tight in most cases .. not sure if other commercial units are either .. good thoughts though ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
RevBill is offline   Reply With Quote
Old 01-18-2015, 09:46 AM   #13
Engine: Int DT466
Rated Cap: 48
I put a tilt down door that doubles as a loading ramp Charlie
Chasgoat is offline   Reply With Quote
Old 01-18-2015, 12:13 PM   #14
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 8 Assengers 2 ATV's
Those style doors would be anchored to a building... how much pounding would they take bouncing up and down the road?
Chasgoat: How long is your ramp, does it go up to the curve in the roof or below the lights?....or did you drop the floor or raise the roof? how much of a pitch is the ramp?
Thanks
Old 01-18-2015, 02:32 PM   #15
If you could direct me to pics of a ramp setup Plzzzzzz
MadFrogPB is offline   Reply With Quote
Old 01-25-2015, 04:40 PM   #16
gizmoq's Avatar
Year: 1978
Chassis: Lifeguard
Engine: 366 Chevy
I can't take credit for the conversion, but I did rebuild it to withstand higher loads. My back door is 7 1/2' x 7 1/2". It uses 2 3" hydraulic pistons bolted underneath the dovetail. Requires no power or hydraulics to open, but needs engine and pump running to close.
http://www.skoolie.net/forums/showpo...8&postcount=13
gizmoq is offline   Reply With Quote
