Old 02-23-2018, 09:34 AM   #1
Roll-up security shutters inside windshield on FE flatnose
Hey everyone,
I am looking for ways to secure my bus, including the windshield. I found some low profile roll-up security shutters that I think will fit under the front bulkhead, above the windscreen. Has anyone tried something like this?
Qompact Technical Details | Roll-a-way
I requested a quote, I'll keep y'all posted.
Lowkee is offline   Reply With Quote
Old 02-23-2018, 11:28 AM   #2
Robin97396's Avatar
Well no, not that I've heard of. Most of us use curtains of some sort. Some use blinds. Honeycomb blinds work best from what I'm told.
I understand your idea. I've also thought of having some type of cover for the windshield but I imagined it on the outside. Perhaps a cover that could sit on the roof above the driver's area that could be lowered to cover the windshield?
It gets very complicated and cumbersome. That's why most of us use curtains or panels cut from sheets of insulation that fit tightly against the inside of the windshield. I also put insulation panels in my side windows to reduce heat loss/gain depending on the climate.
Robin
Nobody's Business
Old 02-23-2018, 12:51 PM   #3
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Do you have a real reason for wanting/needing this level of "security"?
JD - Full timer out west
My Adventures & Build
Old 02-24-2018, 11:58 PM   #4
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Hey everyone,
Rolladen do more good on the outside on a house, but you'd still get some benefit on the inside. It won't keep vandals or a storm from breaking the windshield which would be a nice benefit to them usually. I know people install roll-up awnings on the sides of their busses. I know it won't do the mpg any benefit on the outside.
Sent from my XT1585 using Tapatalk
2martins is offline   Reply With Quote
Old 02-25-2018, 08:48 AM   #5
Yes, traveling solo to South America. Bus will be sitting alone for long periods while I'm out adventuring. I have a lot of expensive gear.
Old 02-25-2018, 08:53 AM   #6
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Ahhh yes! Makes sense! Apologies for the questioning...
Old 02-25-2018, 10:46 AM   #7
Questions are more than welcome!
Although it won't look as clean, I am now thinking of installing the shutters on the outside of the windscreen, to prevent damage. Alternatively, I'm looking at 3M window security film. It won't help if someone smashes the windscreen but will take much, much longer for them to get inside than nothing at all.
Old 02-25-2018, 11:39 AM   #8
Robin97396's Avatar
Buddy I hate to tell you this but if someone wants to get into your bus while you're not there, there isn't much you can do to stop them. Your best bet is to park your bus near a community if you're going to leave it for an extended period of time.
Robin
Nobody's Business
Old 02-25-2018, 11:45 AM   #9
Chassis: 3000RE
My suggestion would be to get permission to park it in a church parking lot each place you plan to leave it and make a donation to the church. They are less likely to steal from a bus that might be a visiting missionary's. No guarantee mind you, bit it will help. I assume you speak Spanish well enough to do that since you are going alone.
Old 02-25-2018, 11:58 AM   #10
Robin97396's Avatar
Or you can hook your electrical system up so the bus has a hot skin. Nobody will touch your bus twice.
Robin
Nobody's Business
