Old 05-14-2017, 01:27 PM   #21
Jolly Roger's Avatar
Engine: Detroit 8.2
I have several ideas in my head using aluminum t-5 clamps designed to fit standing seam roof panels/commercial metal roofs that are easily (because there aluminum ) modidified if need be. Many variations and full web sight to pick the ones you want including ones to fit the gutter on a bus and they will give you the strength rating of each anchor point in the application.if that's your choice?
I would choose a side rail load of the bus structure over anything penetrating the roof personally.
If I secure anything to my roof as far as the rack idea the legs will be tall enough for me to use roofing boots on each leg and if I secure to the ribs down the sides it will be with bolts drilled all the way through to the inside and visible so that I can check and tighten as needed?
But that's me?
I do a lot of commercial and govt work and every working part needs to have access to check and tighten as the years go on!
There's a reason why? To me anyway. SAFETY for the ones on a ROOF TOP DECK?
Old 05-14-2017, 04:57 PM   #22
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Originally Posted by Carytowncat View Post
I find eating a daily dose of dark chocolate first thing in the morning, makes me a happier person.
Doctors say I can't have chocolate any more. And there's an even longer list of things I can only have in moderation. Dialysis really puts a crimp on one's lifestyle.
Old 05-14-2017, 06:50 PM   #23
BurlKing's Avatar
Year: 92
Engine: DTA360 5.9L
not mine, but maybe it can give you some ideas on a different approach, i have seen many that go mount on the side of the bus between the windows then up.
BurlKing is offline   Reply With Quote
Old 05-14-2017, 06:53 PM   #24
BurlKing's Avatar
Year: 92
Engine: DTA360 5.9L
this guy also does a great roof deck, check it out on the first page more towards the bottom. I most likely will go the same route as him.
http://www.skoolie.net/forums/f11/19...stle-9911.html
Old 05-14-2017, 08:34 PM   #25
Ryannmelis's Avatar
Coachwork: Wayne Corp
That is Bad A$$
Sent from my SAMSUNG-SM-G891A using Tapatalk
1990 International 3800 DT360 and AT545.
2007 Dodge 5.9 with a 6 speed.
6 Kids,1 Cool Ol Lady
Lots of life to live.
Ryannmelis is offline   Reply With Quote
Old 05-15-2017, 09:19 AM   #26
Roof Rack
Looks very comfortable!
My initial planning is going to include using the tubular seat framing from our bus to build a safari rack for the roof.
Every plan is a dream right now. Every day passed is a day closer to the future that includes a bus conversion.
John.Smith is offline   Reply With Quote
