You will probably get more luck posting in the Conversion Discussion section rather than in the Board Problems section.
I know this refers to trailers, but I think it is a good guide for vehicle height as well. The specs are probably the same. Either way, I'd call the local authorities on the issue. Same goes for the safety inspection question.
http://www.camping-canada.com/towing_regulations_e.htm
