Old 02-23-2017, 10:40 PM   #1
Wutm8's Avatar
Roof raise cost?
I've done some research and can't really find prices. After all was said and done how much did you end up spending on your roof raise? I'm hoping I can fit in my budget
I'm going to do as much as I can myself. From cutting and raising but I can't do any of the welding myself. I've got a 40 foot bus and it's looking to raise 24in
My conversion https://www.skoolie.net/forums/f11/a...ous-16828.html phoenix az
Ig gypsybirdbus
Wutm8 is offline   Reply With Quote
Old 02-25-2017, 10:28 PM   #2
Engine: t444e
You don't *have* to weld, you could drill & bolt.
ChiliChzPoopTart is offline   Reply With Quote
Old 02-26-2017, 06:33 AM   #3
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
Depends on many things. Are you reusing the windows ? I think 1500 in materials is a good guess. You can spend 2500 on windows and doors .
my build pics
Old 02-26-2017, 10:53 AM   #4
Chassis: Blue Bird
Engine: ISC 8.3
There's no inherent need to weld a roof raise. Rivets as in the original construction are also an option. Solid rivets if you have access to both sides, or blind if you don't. A fair 3X or 4X air hammer for setting solid rivets will set you back around US$200-300 IIRC.
Old 10-05-2017, 06:51 PM   #5
Engine: dt466e
OP, have you had any progress on the roof raise?
adic27 is offline   Reply With Quote
Old 10-06-2017, 01:17 PM   #6
Brewerbob's Avatar
Depends on your local market. What's the going rate for a pint tears, a quart of blood, and a gallon of sweat?
The new sheet metal for my raise (6 pcs 4x8 and 5 pcs 4x10 sheets of CR 18ga) is $487.66. I bought a Hobart 140 for this project tho I don't plan on welding the skins. I welded patches on the floor and will likely use it to build many other things such as frames for holding tanks, storage, etc. I have NOT bought rivets to replace the ones I'm pulling. No idea yet on ceiling and floor treatments tho probably wood (no riveting/welding for that). Without doing interior walls/floors/ceilings I think I am going to need about 500 rivets to replace existing. Maybe another 300 or 400 for new rivets.
Haven't done my raise (yet). I have another 250 rivets to go. Will almost certainly buy the sheet metal this coming Monday. I have the day off to go pick it up, get drunk, and cry in my beer. What the hell was I think with this project???
Old 10-06-2017, 01:24 PM   #7
No matter what it costs, it sure beats the hell out of paying someone ten or twenty grand to do what can be done in a weekend with some friends!
Old 10-06-2017, 01:31 PM   #8
Brewerbob's Avatar
One weekend my butt. Your bus is still a little breezy.
Old 10-06-2017, 02:06 PM   #9
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Old 10-06-2017, 05:50 PM   #10
Well- to raise the roof took LESS than a weekend.
Paneling it in, that's another weekend. I just haven't had THAT weekend yet!
Old 10-06-2017, 07:57 PM   #11
Traveling
Rated Cap: '00
Congrats ECCB!!!! That is your 11,000 post !!!! Woot !!!!
Old 10-06-2017, 08:36 PM   #12
Damn, that's a lot!
Old 10-06-2017, 11:37 PM   #13
Traveling
Rated Cap: '00
Damn, that's a lot!
You are 10x the man I will ever be !!!
Me and Brewer Bob are going to ride your ass until you finish the big bus.
Old 10-07-2017, 06:48 AM   #14
Join the list of folks who do so.
Old 10-10-2017, 07:38 AM   #15
Brewerbob's Avatar
Lol, fair enough. Keep dragging your feet and I'm going to get ahead of you. Bought the sheet metal yesterday. ****'s about to get serious.
Damn straight.
It's probably a long but honored list which I can live with.
Old 10-10-2017, 07:41 AM   #16
Roof raise cost?
How bout bus and roof raise for $6500?
Old 10-10-2017, 12:00 PM   #17
Brewerbob's Avatar
Roof raise cost?
My a$s you are. Get back to work on it.
