Old 10-07-2019, 09:15 AM   #1
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Roof raise on a conventional bus?
Hey alls..
Been searching a bit as I'm considering a roof raise on my '93 IH (Ward body) but I don't see many conventional buses with roof raises. The majority I've seen are flat nose.
Anyone have any good examples of conventional bus roof raises?
Thanks
Old 10-07-2019, 09:20 AM   #2
Originally Posted by Mr4btTahoe View Post
Hey alls..
Thanks
Ward is a good one to raise. I did a 92 Ward Senator. Mine was a FE but raising the roof is the same.
Roll Your Own Build Thread
Old 10-07-2019, 09:41 AM   #3
Engine: DT466E-Md3060
Hey alls..
Thanks
Here's a few pics I found (googled), hope this helps keep the inspiration juices flowing!
Old 10-07-2019, 09:51 AM   #4
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Anything to watch out for on them? Fairly straight forward? I've never done a roof raise but am not new to metal fab.
Old 10-07-2019, 10:29 AM   #5
If you've done metal fab you'll find roof raising is pretty darn easy. It sounds a lot more complicated than it is.
Get some channel made- there is no commercially produced tubing that will fit in the ribs, so you'll need inserts made. Make sure they're snug, don't use spacers.
Old 10-07-2019, 12:19 PM   #6
Keep in mind Thomas buses taper in as they rise from the bottom of the windows.
Old 10-07-2019, 12:23 PM   #7
No worries there- its a Ward.
Old 10-07-2019, 12:28 PM   #8
Just FYI for others.
