05-10-2019, 12:40 PM
Coachwork: Tomas
Engine: 7.3l
Roof raise sheet metal?
Preparing for roof raise
Wondering what quage people are using to cover side of bus after a roof raise. I know I've read somthing about this before but cannot find it. Thanks in advance
05-10-2019, 12:56 PM
I used 20g, many here recommend 18g, but the 20g went up fine without oilcanning.
05-10-2019, 04:23 PM
Coachwork: Tomas
Engine: 7.3l
Thanks, 20 Guage is cheaper. Hehe
05-10-2019, 04:29 PM
Just don't go thinner than 20. Had someone bring me 22ga to patch some stuff. Man its just too flimsy.
If anyone in FL wants any 18ga hit me up. $65 for a 4x10.
05-10-2019, 04:47 PM
Best bet is to use sheetmetal that is closest to the original. For most Skoolies, that will be around 16.
05-10-2019, 05:08 PM
Is your 46 16ga?
I used some 16 I got for free to patch a roof hatch hole and its definitely way thicker than the rest of the bus' skins. Did the job nicely though.
My subaru is 26ga! It feels weird its so flimsy and light. It dents if you look at it too hard!
05-10-2019, 05:12 PM
Like a lot of Skoolies, mine is an oddball. Actually measures about 15 gauge. BB's are similar. I used 16 in some places and even 14 in a few others (window deletes, door skin).
05-10-2019, 06:03 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
correct me if I'm wrong - roof skin is lighter weight than wall skin because of the shaping that has to be done - if needed, I plan on getting a donor school bus shell for the sheet metal and hat channel
05-10-2019, 06:06 PM
That would be pretty expensive, and its easier to work with new steel, IMO.
What would you need factory hat channel for? Wouldn't you want it to fit into or onto the old stuff if you're raising it?
05-10-2019, 06:14 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
you can get a stripped bus body for $1 ( plus cost of hauling it - I have my own trailer so that helps if I can't find a truck heading back this way with no load ) - I figure using the correct hat channel will save a lot of time and welding wire, over square tubing and angle iron to give something to fasten the skin to, and it would save a lot of drilling as well - used body panels are already primed for easy painting
https://www.kijiji.ca/v-cars-other/s...ationFlag=true
05-10-2019, 07:07 PM
I mic'ed the 12" square that I cut out with the roof passive vent. It measures .040+", or 19ga. If I really get tight on the caliper I can get it down to .0385, if you take into consideration the paint on it I would say the roof is only 20ga.
05-22-2019, 06:30 AM
Coachwork: Tomas
Engine: 7.3l
That same sheet is 165 here in MB Canada
05-22-2019, 06:33 AM
Coachwork: Tomas
Engine: 7.3l
Thanks to all
Decided to go with 18ga
05-28-2022, 12:27 PM
Chassis: VIN = 1T7HR3B2311090770
Rated Cap: ~72
$$$ now ?
Hi! What is the price now for 4x10, please?
05-28-2022, 09:03 PM
I haven't checked in a couple years. I'll ask monday but I'd be expecting some sticker shock.
Looking online I've seen em as high as a buck fifty apiece.
05-29-2022, 08:37 AM
Rated Cap: ~72
Thank you.
Hard to believe online prices are the best I can get.
05-29-2022, 09:17 AM
Have you called steel suppliers locally?
05-29-2022, 10:24 AM
Rated Cap: ~72
Local suplier ? ...
The most local supplier hasn't returned my call. I will call them again.
05-29-2022, 10:43 AM
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Where is Local?
Fill out your location in the [User Profile] > [Edit Details] so that skoolies near you can chime in with additional info or a local source.
That's how ECCB found me. GAVE me several precut patches for the hatches, strobe, vent, & eight warning light deletes. All that, from filling out my profile. Good people found me.
(*Thanks again, Charlie!)
05-29-2022, 10:54 AM
Chassis: TC2000 28ft
I just bought a 5x10 of 18g galvannealed for $225.
For reference, 18 Cold rolled 4x10 is $216.
16g Hot Rolled 4x10 is $156
11g Hot Rolled 4x8 is $226
This is from the lowest steel supply in town. My quotes at Alro and Metal Supermarkets were about 50% to double.. But they are great for partial lengths of material.
