Old 10-21-2009, 05:06 PM   #1
roof raise style
so i want to raise my roof but id like to use vans cut in half, cut them below window, weld on then cut out bus roof. this would make a double shouldered design i feel might be stronger. i got the vans free. plus think of all those big windows up there? ive been thinking about it for a year now trying to decide if its better then the conventional roof raise. also anyone know the exterior height of a 91 bluebird all american re
any opinions
adamanderr is offline   Reply With Quote
Old 10-22-2009, 11:45 AM   #2
Re: roof raise style
but do you think it would be stronger with that hip. i did think it would be snazzy looking too. also do you think it would add too much extra weight. i think it would weigh a tad more than the conventional straight sides
Old 10-22-2009, 12:12 PM   #3
TygerCub's Avatar
Engine: Detroit
Unless you keep the arched roof supports, you will weaken the overall design, not strengthen it. Why? Because the strength lies in the uninterrupted arch of ribs over the ceiling of the bus. Take out a couple of them for entry into a "second floor" created by the van top and you'll be okay. But cutting them all out will not help the strength.
That being said...
Unless you plan on entering a demolition derby with your bus, it shouldn't make much difference to livability . The biggest disadvantage you'd have is no extra cabinet space along the sides. You'd still be reduced to using the original height of the bus and have to fit the cabinets to the remaining curve. You'll have loads more head room, but that's just wasted space in the center aisle.
The type of raise Smitty, Millicent, and others have done gains wall space as well as ceiling space. This is very important in long term living.
If you want to add a van on top, then go for it! It's YOUR bus. If it makes you happy, then it's a great decision. Just weigh the pros & cons of how you plan to use the bus (party bus, tailgater, camper, mobile home, etc.) before you start cutting.
Roof Raise - Building My Own Flat Roof iverSUN Conversion General Discussions 26 02-18-2019 10:41 AM
Roof Raise ~ Cutting Roof ABOVE Windows ?? chev49 Conversion General Discussions 3 12-04-2012 02:07 AM
Bus roof raise? stonestatue Conversion General Discussions 1 09-25-2012 06:31 AM
Roof raise Rod Conversion General Discussions 1 03-08-2008 05:51 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? pixemoss Skoolie Conversion Projects 6 12-31-1969 07:00 PM
