Old 06-09-2019, 07:19 PM   #1
2kool4skool's Avatar
Roof raise thoughts
First, I am not a structural or automotive engineer. I am a retired pole climbing, dirty old linemen.
I have no experience doing roof raises.
I am NOT anti-roof raise.
I have been poking around the internet, looking at the way buses are built.
Skoolies are not built like other buses.
Big old over the road tour buses have a truss frame that doesn't rely on roof/walls for stability. A Skoolie needs it's box intact to be strong.
Build the crap out of your roof raise, return the box to it's original integrity.
These observations are probably worth what you paid for them.
We all know what a Skoolie looks like with the roof (and walls) cut off.
This is what a big bus looks like in the same condition.
I find this very interesting, you may not.
Don, Mary and Spooky the cat.
Old 06-09-2019, 07:52 PM   #2
A central part of a school bus body's integrity is the ribs forming the walls and roof, bent from single pieces of homogenous hat channel material. A roof raise cuts these ribs in two places, and even the best-quality welding and bolting of the rib extenders will still concentrate stresses at those cuts (even if the welds and extenders are stronger than the channel material this will happen) making them prone to fail.
I am also not anti-roof raise, I just don't think people should be expecting their raised buses to be as structurally strong as they were before the modification. Just don't ride in the back of the damn things.
Old 06-09-2019, 07:53 PM   #3
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
lets just say, 'there is less work in doing a roof raise in a tour bus'
Old 06-09-2019, 08:15 PM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Seems like the tour bus has far fewer structural members supporting the roof. The roof looks strong, but man, so few pillars.
School busses are designed by law to resist a roof cave in in the event of a roll over. I wonder how a coach fares in that scenario.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 06-09-2019, 08:19 PM   #5
Chassis: Thomas
Engine: CAT 3126
Some survivors, but some fatalities as well.
My Build Thread:
Old 06-09-2019, 08:25 PM   #6
Chassis: IH
Attachment 34353
That answers that.
Old 06-09-2019, 08:47 PM   #7
Chassis: Thomas
Engine: CAT 3126
Found another angle. Looks like this may not have been a coach style bus. I see a driveshaft so it must be a puller.
That roof though. Just a disaster.
38 onboard, only 1 dead. Hard to believe it wasn’t worse.
My Build Thread:
Old 06-09-2019, 08:58 PM   #8
I think there are other important differences about the weight distribution of a skoolie and a tour bus as well.
If you look at a school bus head-on, it's a fairly short rectangle - it's taller then it is wide, but not by much. (I think general consensus is 8 feet by 10 feet or so.)
A tour bus is a LOT taller. (8 x 11 or 8 x 12).
That extra height means a couple different things. First, if a tour bus rolls over, it's more likely to roll onto it's side, and stay there. It's a tall rectangle sideways - there's not that much of a chance that it's going to continue to roll onto the roof. I also wouldn't be surprised if tour buses have a lower center of gravity in the first place- larger engines, closer to the ground, and just more weight in axles, engines, luggage bays, etc. So if you look at the framing on the tour bus, the heavy stuff is down low - it goes to the bottom of the windows, which is enough to support the bus on its side. The roof and windows are designed to keep it from rolling over, not exactly to fully support it upside down. While you're giving up a bit of roof integrity, you're also helping to keep the center of gravity lower - which lets you have a nice, tall roof height in the first place. (At least, that's what I believe the design logic is.)
There's also the fact that a school bus, at 55mph, is going to have vastly different physics then a coach bus doing 75. Not to be morbid, but at some point, it doesn't matter what you do, the results aren't going to be pretty. That said -
There are roughly 128 people killed every year in school-bus related crashes in the US. 9% of those (11 people) were passengers riding the bus - the vast majority were either pedestrians, or occupants of other vehicles in the crash(es).
https://crashstats.nhtsa.dot.gov/Api...ion/812476.pdf
If you go here, in 2016, there were 10 people killed in motor coach accidents. (14 in transit buses, 3 in vans, and 27 in "other" buses. Also 10 in school buses.)
https://www.fmcsa.dot.gov/safety/dat...ash-facts-2017
(Scroll down to Trends Table 25.)
So overall, at least as buses, these things are pretty darn safe. I'm not qualified to say that 10 lives/year is enough to re-design the way we build over the road buses.
Old 06-09-2019, 09:01 PM   #9
Chassis: Thomas
Engine: CAT 3126
Also, interesting statistic - there are roughly 128 people killed every year in school-bus related crashes in the US. 9% of those (11 people) were passengers riding the bus - the vast majority were either pedestrians, or occupants of other vehicles in the crash(es).
Good analysis.
My Build Thread:
Old 06-09-2019, 09:02 PM   #10
Attachment 34355
I just watched the helicopter video that this still was taken from. Looks like this was a shuttle bus, so not surprising that it was crushed like this. A good reason not to base your conversion on something made out of fiberglass.
Here's the video: https://www.facebook.com/WYFF4/video...5445552094114/ At about 6:55 the camera pans back to a second bus (undamaged) from the same church that appears to be the same type of bus.
Old 06-09-2019, 09:12 PM   #11
Roof raise
One consideration, depending where you drive will be cross winds. A roof raise may require extra caution in a heavy cross wind.
capnron is offline   Reply With Quote
Old 06-09-2019, 09:30 PM   #12
I think this statement is not based on fact at all. You are only cutting the rib in one place, not 2. if the extenders are long enough, the cuts of the rib will sustain zero stresses. You make it sound as though the ribs were designed to function at their maximum, when they are probably manufactured to sustain at least 50% more than normal use. Will the weld areas be weaker past the weld, yes, but certainly not enough to make it "prone to failure". There's no reason a proper roof raise can't be as strong as before, or at least way stronger than it needs to be. Prone is a strong word to use for an issue I've never seen an example of.I can think of other reasons I wouldn't do a lift, none of them involve the strength of the raise.
Old 06-09-2019, 09:41 PM   #13
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
either way, buses in general are MUCH safer than factory built motorhomes
Old 06-09-2019, 09:47 PM   #14
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
l agree - most raises even buttress the welded joins in the hat channel
Old 06-09-2019, 10:05 PM   #15
The rib is a single piece of hat channel material that forms both walls and the ceiling. To do a raise, you make one cut on each wall side - that is 2 cuts.
How many skoolies have ever rolled? Real-world testing is the only way these issues could ever really be resolved. Without that, we're all just guessing.
Old 06-09-2019, 10:05 PM   #16
Part of the problem actually could be that the roof raise is STRONGER. When you engineer something, you engineer the whole thing as a system - certain components are engineered to fail in certain ways (and at certain times.) Think about adding leaves to the springs of an old dump truck - it will carry the weight for a while, but that extra stress is still going to go somewhere - until eventually you hit a pothole, and instead of the suspension giving way, the frame cracks and gives way instead.
If the bus rolled, the factory ribs might all bend, and the bus gets squashed, but stays intact. Example : It's crushed a bit, it's bent (a LOT), but it's intact.
If the ribs were too strong, it's possible that the roof /could/ snap right off the rest of the bus. Maybe the roof wouldn't snap right off, but it if was strong enough, it could bow out or tear the side wall instead.
Designing points of failure can be complicated.
(I still think I'd trust a roof raise over a sticks n staples though.)
Old 06-09-2019, 10:19 PM   #17
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
we're talking granite and bunny fluff - bus to motorhome
Old 06-09-2019, 11:35 PM   #18
I stand corrected on the number of cuts.
My point exactly on the real world testing lacking any results at all, so saying a roof raise is prone to failure is pure speculation on your part.
Old 06-10-2019, 03:32 AM   #19
Bluebird commercial buses and Wanderlodges have half the ribs of the vastly overbuilt school bus.
The timidness of this forum is palpable.
Old 06-10-2019, 03:34 AM   #20
The ribs are actually 3 pieces on most of the buses I've owned.
