Old 05-29-2008, 03:24 PM   #1
Xtevan's Avatar
Coachwork: BLUEBIRD
Roof Top AC installs
I put a Dometic unit on my roof about a month ago. I made a pig tail and tested it. I've been fighting with the generator ever since . I need to run permanent wiring and a condensate line. Do I pull the wires between the inner and outer roof or run some type of conduit? How should I handle the condensate drain hose? If I pull it through the inner/outer roof do I drill out at the roof edge and have it run down th side of the bus or come down one of the window frames to the floor and out under the bus?
Steve
Xtevan
Bus Project Pictures
https://picasaweb.google.com/XtevanofthePlaya
Xtevan is offline   Reply With Quote
Old 05-30-2008, 12:59 PM   #2
Xtevan's Avatar
Coachwork: BLUEBIRD
Re: Roof Top AC installs
The AC unit came plumbed with the outlet tee in the center of the 14X14 body opening, so to run it out on the roof I'd have to cut a hole for the hose in the roof gasket. Which might make getting a good seal hard.
Xtevan
Old 06-02-2008, 12:46 PM   #3
Engine: 7.3 diesel
Mine also runs right on to the roof and down the outside. I have seen on buses with factory air in the rear run the hose to one side or both if equipped with two hose hook ups, down behind the interior panels and through a hole in the floor straight down about 6 to 12 inches and to the ground.
Why roof-top AC? GoneCamping Conversion General Discussions 7 08-15-2019 06:40 PM
Roof Raise - Building My Own Flat Roof iverSUN Conversion General Discussions 26 02-18-2019 10:41 AM
Roof Racks/Deck... Side mount vs. roof mount? TygerCub Conversion General Discussions 37 08-14-2018 07:57 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? chev49 Conversion General Discussions 3 12-04-2012 02:07 AM
Roof Raise ~ Cutting Roof ABOVE Windows ?? pixemoss Skoolie Conversion Projects 6 12-31-1969 07:00 PM
