Old 05-04-2012, 03:04 PM   #1
Re: Roof Weight Question
that is not excessive at all.. after all 1000 lbs is only the weight of 4 healthy people on the roof...
skoolie roofs have huge support structure, as they are not crushed when the things get in a wreck.. after all, they are built to protect the crumb crunchers...
the ONLY disadvantage i see is that the additional weight being like 12' off the road, which pushes the center of gravety higher... which means ya gotta be way more careful driving around corners, especially in wet weather...
i havent put solar panels on my roof yet, will do so this year sometime, and am not concerned about the weight at all.. i think i want somewhere around 1000 watts.
again, always remember the center of gravety if you are driving fast cause things are fine until in the middle of the corner the bus almost tips over.... been there both with freight loads with the peterbuilt and with my flx bus when being an idiot...
Old 05-04-2012, 05:24 PM   #2
Jerry Campbell's Avatar
Year: 1975
Engine: DD 6-71N
If you're worried about the weight use aluminum angle for the racks and supports.
700 lbs is a lot of wasted energy
Jerry
Jerry Campbell is offline   Reply With Quote
Roof deck structure question PDBreske Conversion General Discussions 12 02-01-2012 05:41 PM
Powered roof vent question BUSBOZO Conversion General Discussions 0 07-13-2010 07:31 PM
Raising the roof skoolie question Gyva Conversion General Discussions 2 02-09-2010 03:37 PM
Shortbus roof rack question lbethards Short-Bus Conversion Projects 6 07-02-2009 03:59 AM
question for roof raisers adamanderr Conversion General Discussions 4 02-03-2008 09:20 PM
