Old 02-18-2007, 05:43 PM   #1
BBTC2K's Avatar
Year: 1983
Coachwork: GMC
Chassis: RTSII
Engine: 6V92TA
Rated Cap: 55
Send a message via AIM to BBTC2K Send a message via Yahoo to BBTC2K
Rooftop AC in place of escape hatches?
I was wondering if anyone has ever used their roof hatches as a spot for either roof ac or fantastik fans?
If so, how did you get them to fit?
thanks
shawn
School Bus Driver/Instructor/Mechanic...
proud single custodial dad to 18yr old son Jeremey, who wants to try his hand at driving my RTS
BBTC2K is offline   Reply With Quote
Old 02-18-2007, 06:45 PM   #2
oldog12's Avatar
I often wondered about the same thing... Just eye-balling it, it looks as though they're made to order for a roof mounted AC unit
oldog12 is offline   Reply With Quote
Old 02-18-2007, 08:53 PM   #3
eggman's Avatar
The way it looks to me, is that the emergency roof top opening is around 18-20 inches, where the roof top is meant for 14 inches.
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 02-18-2007, 09:32 PM   #4
frank-id's Avatar
Roof vents
Most buses roof hatches are larger than size required for a AC unit. The hole needed for a fan or AC unit is 14 1/8 inch. Covering an existing hole usually requires some roof work and some method of reducing the hatch hole. Most roof AC units use long bolts to clamp unit to the roof with no fasteners connected to roof. Carrier units are the most expensive but seem to me to be the best of the AC units. Frank
Old 02-19-2007, 09:40 AM   #5
oldog12's Avatar
Wow, it sure seems a waste not to use those holes...
Old 02-19-2007, 09:59 AM   #6
Steve's Avatar
Better that the holes are too big, if I had escape hatches I would definetly make some adapters to use them for A/C. With all that space around it you could make some really nice trim.
Old 02-19-2007, 10:25 AM   #7
oldog12's Avatar
I was thinking along the same line... its there, might as well use it...
Old 02-19-2007, 11:49 AM   #8
frank-id's Avatar
Roof vent hole
I think the most important consideration for roof AC is placement. My Crown bus has 2 roof AC units and a center fantastic vent. One AC is at thr very front of the bus to allow some creature comfort while traveling down the hiway. I think I'm also gonna make a curtain to restrict the cooling air to be a the most value to the driver. I mostly travel alone. My bus is not yet insulated so heat and cooling are not great. My plan is to drill many 1/2 inch holes and inject insta foam with care. After foam has stopped expanding, carpet will be glued to ceiling, and with wood strips screwed in place. Frank
Old 02-19-2007, 12:00 PM   #9
oldog12's Avatar
I was also wondering about carpeting my ceiling in hopes of increasing the R value, I'm just a little concerned about the glue not being able to handle however hot the roof/ceiling may get
Old 02-19-2007, 12:17 PM   #10
Steve's Avatar
I think the best benefit of the carpeting is the sound deadening you will get from it.
rooftop vent proconsul100 Heating, Cooling and Appliances 15 12-04-2012 09:41 AM
The Great Escape....Soon MichaelsMission Skoolie Conversion Projects 1 11-24-2010 06:03 PM
Rooftop Decks arfisher83 Conversion General Discussions 9 08-13-2009 03:05 PM
large selection of doors/windows/hatches keith Classifieds | Buy, Sell, Swap 0 03-03-2009 07:22 PM
What to do with roof safety hatches? dammitAndy Conversion General Discussions 17 04-27-2005 05:24 PM
