Old 05-21-2019, 03:33 PM   #1
Year: 2006
Coachwork: Collins
Chassis: Chevrolet
Engine: 6.6 LLY Duramax
Rough idle and check engine light too!
First startup in a bit made for excitement draino. Any recommended mechanics in the Oakland Ca area?
Epomethius is offline   Reply With Quote
Old 05-21-2019, 04:54 PM   #2
brokedown's Avatar
Your bus should have a typical GM ECU with OBD2. Any autozone can pull the codes from the computer for free, I'd start there.
Old 05-21-2019, 06:07 PM   #3
Chassis: International 1753
Engine: 6.9 International
Yeah what he said. If it's got a duramax, you should be able to pull engine codes with any generic obd2 reader.
Old 05-21-2019, 08:20 PM   #4
Year: 2006
Coachwork: Collins
Chassis: Chevrolet
Right! P0191
Funky idle went away after warming up. The battery was low when starting and perhaps that was the root cause. The internet has someone with a similar story.
Trying to start the truck with a dead battery will set this dtc also. As will connecting the battery with the key on.
From this site https://www.pirate4x4.com/forum/tow-...r-2k-help.html
Old 05-21-2019, 11:01 PM   #5
Rovobay's Avatar
Rated Cap: 35
I have an LLY duramax in my 2005 Silverado. I use this forum whenever I need to (which thankfully has not been in a very long time) I even got enough courage to change my headgaskets through the info on that site. it took 2 weeks every day after work but several years later. no problems.
https://www.duramaxforum.com/forum/
My Build: https://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
