Old 09-23-2014, 09:44 AM   #1
Coachwork: ward
Chassis: international
Engine: dt360a
rounded door
ok, most of my walls are done as is subfllor. next is the entrance door. the door(s) on my 88 ward is a typical bi-fold but is not square. the front top corner is rounded. anyone ever istalled a house or rv style door on one of these? if so, how? i was given a house door that is metal on outsides with glass in center, but the top right corner will have to be modified. all ideas welcome!
Old 09-23-2014, 10:20 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: rounded door
How about a picture so we can see what you have to work with?
somewhereinusa is online now   Reply With Quote
Old 09-23-2014, 11:46 AM   #3
Coachwork: ward
Engine: dt360a
Re: rounded door
thanks somewhere. will try to put one up.
Old 09-23-2014, 01:36 PM   #4
Coachwork: ward
Engine: dt360a
Re: rounded door
Old 09-23-2014, 01:37 PM   #5
Coachwork: ward
Engine: dt360a
Re: rounded door
Old 09-23-2014, 01:38 PM   #6
Coachwork: ward
Engine: dt360a
Re: rounded door
Old 09-23-2014, 02:40 PM   #7
Chassis: AARE
Re: rounded door
How wide is the door, how tall is the door? How wide is the door opening at the widest part? How tall is the door opening?
Are you a welder?
Old 09-23-2014, 02:46 PM   #8
r_w
Re: rounded door
I don't think that door will work, looks like you would be cutting into glass.
If you had a solid door (no glass) you could cut it to fit and then add a smaller glass window later, OR... you could square off the opening and use a narrower door--the door is smaller but the opening will be about the same as what you have now with the bifold in inside the doorway.
r_w is offline   Reply With Quote
Old 09-23-2014, 03:16 PM   #9
turf's Avatar
Re: rounded door
you might try the door upside down..... glass on bottom.....and trim the solid portion of the door. maybe install another window in it.
a metal wrap door isnt the easiest to work with..... something will have to cover your new cut edge.
Turfmobile Build Thread
Old 09-23-2014, 09:49 PM   #10
Re: rounded door
Weld the door pieces together and re hinge it.
Old 09-24-2014, 09:26 AM   #11
Coachwork: ward
Engine: dt360a
Re: rounded door
Are you a welder?
door and opening are 32". dont remember but the height of door is around 4" taller than opening, i am not a welder, but can weld and have access to nice welding rig mounted on a trailer.
thanks
Old 09-24-2014, 09:28 AM   #12
Coachwork: ward
Engine: dt360a
Re: rounded door
thats what my buddt suggested, but i was looking for less work and less welding.
Old 09-24-2014, 09:30 AM   #13
Coachwork: ward
Engine: dt360a
Re: rounded door
thought about that, also thought about filling window with wood or sheet metal. how would one cut the door? what tool would work best?
Old 09-24-2014, 09:32 AM   #14
Coachwork: ward
Engine: dt360a
Re: rounded door
are you talking about reusing the original door?
this would work lots better if i knew how to multi quote!
thanks yall.
Old 09-24-2014, 11:54 AM   #15
Re: rounded door
yes that's what he ment, lorna,me and several others have done this
Old 09-25-2014, 08:53 AM   #16
Coachwork: ward
Engine: dt360a
Re: rounded door
thanks, no problem with that much weight hanging and bouncing? what type hinges? how did yall do the lock and knob?
Old 09-25-2014, 09:10 AM   #17
Chassis: AARE
Re: rounded door
I think you'll find that the original front hing can be turned around so that the door opens out. I would think something like this
http://www.morehandles.co.uk/scotch-rim-lock.html could be adapted for a latch. Although a quick search only found new ones in UK. You
can find plenty of older used ones, but only have a skeleton key.
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 03:54 PM
Replacing bus door with storm door??? leadsled01 Short-Bus Conversion Projects 13 03-18-2014 08:31 AM
Replacing the door with ext house door? jkronmiller Conversion General Discussions 2 06-10-2013 03:05 PM
Side door/ Rear door SeanF Conversion General Discussions 6 05-24-2009 12:56 PM
Anyone ever used the bifold door as camper door ? RichardRWatson Conversion General Discussions 6 07-04-2007 10:27 PM
