Old 07-29-2009, 06:05 PM   #11
Chassis: Ford B700
Engine: 5.9L Cummins
Re: Rub Rails
Originally Posted by Papabear
Originally Posted by vanguy67
I agree. I think my bus would look better without the rub rails too. Unfortunately, Bluebird, in their infinite over-engineering wisdom, shot a rivet EVERY TWO INCHES!! in my rub rails and I don't want to have to patch 800 holes per side just to get the streamlined look. I would be a raving maniac!!
For me, rub rails stay.
DITTO, my Wayne is the same way, and they are hard ass solid rivets. Not the kind that you can punch out the center and then drill out. I hate rivets AAAAAAARRRRGGGGG!
The kind you grind all of the heads, air chisel and cross your fingers that you can punch them through. Then you get to hear them rattle around the inside of the wall for eternity. Rivets are wonderful!
kamoo is offline   Reply With Quote
Old 07-29-2009, 06:18 PM   #12
ezbme's Avatar
Coachwork: Thomas Transit Liner
Engine: CAT 3208 Turbo
Re: Rub Rails
Theres GOT to be a special tool to remove the bastards....
Maybe something like this?? They state that the Blind Rivet Tool will remove solid rivets...
Might work!
http://www.averytools.com/c-21-rivet-cu ... tools.aspx
ezbme is offline   Reply With Quote
Old 07-29-2009, 07:19 PM   #13
tfdfyrman's Avatar
Chassis: Safe-T-Liner
Re: Rub Rails
They do make a rivet shaver but you have to buy the tool that the bit goes into. I saw the shaver tips when I bought my solid rivet driver head. I just cut a slot in them and hit them with a air chisel tip. They have been popping right off.
tfdfyrman is offline   Reply With Quote
Old 08-10-2009, 02:50 PM   #14
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
Re: Rub Rails
I am removing mine....I found plastic plugs that snap into the holes.. Where there are main frame rail I installed new rivets
What happens on the trail stays on the trail
Kirbystud is offline   Reply With Quote
rub rails bigdan Conversion General Discussions 16 02-27-2013 01:12 PM
Purpose of Rub Rails? syke Conversion General Discussions 8 04-22-2012 09:40 AM
Side rub rails - why keep them? dgorila1 Conversion General Discussions 2 09-11-2011 03:26 PM
Welding to Frame Rails? The Slims Conversion General Discussions 15 12-12-2006 09:38 AM
rub rails bigdan Conversion General Discussions 0 12-08-2003 12:40 PM
