Old 11-01-2019, 12:02 AM   #1
Member
Year: 2011
Coachwork: International Aero Elite
Rubber Door Seals
Hi. I sure hope someone can help me. I have been looking everywhere for the rubber seals on the doors of my shuttle bus. I found some for resealing all my windows at Lowes. But the HUGE rubber seals that go on the entrance door and wheelchair lift doors and back door all need replaced. Can't find them anywhere.
vi_king2013@yahoo is offline   Reply With Quote
Old 11-03-2019, 02:11 AM   #2
I would suggest the dealer. They should have them in stock (or can order them) and they should not cost any more then anywhere else you might be able to find them.
Old 11-09-2019, 10:10 PM   #3
Frochevy's Avatar
Chassis: Collins
Engine: 6.6L LMM Duramax
Are you looking for the bulb rubber seal that fits on the edge of the sheet metal? If so, check Amazon out. Just make sure you get the right thickness. I ordered mine from amazon...
Trim-Lok Trim Seal with Side Bulb - PVC Plastic Trim with EPDM Rubber Bulb Seal - Fits 1/8" Edge, 3/4" Bulb Seal Diameter, 25' Length https://www.amazon.com/dp/B00NL46NOY..._x14XDbBS1YWT5
2007 Collins (Chevy Express 3500)
LMM Duramax Diesel with newly rebuilt 4L85E Transmission!
Frochevy is offline   Reply With Quote
Old 04-11-2024, 04:18 AM   #4
Rubber door seals
Busparts com I just r received mine.
Sbaja13 is offline   Reply With Quote
