Old 08-19-2007, 12:44 PM   #1
Year: 88
Engine: B700
Rated Cap: 71
Run Away Diesel! - '88 Ford B700 Won't shut off.
Hi, I'm new to diesels - I've got 6 buses I use for a party bus business - 5 gas, one diesel.
On a party last night, the bus wouldn't shut off.
It's Sunday today so no mechanics are working - to call and ask questions. I've unhooked the positive leads on the batteries and also the positive lead on the alternator . . . What next? I thought about unscrewing the the fuel filters, but from what I've heard, if you run a diesel out of gas, its a bear to get it started again - so I haven't gone this route yet.
There is not a fuel shut off button anywhere and I can't find a manual valve or something under the hood. Does anyone have any suggestions for me?
Thanks, Jason
jasonvandyke is offline   Reply With Quote
Old 08-19-2007, 07:25 PM   #2
Engine: 7.3 diesel
Re: Run Away Diesel! - '88 Ford B700 Won't shut off.
I'm sure you got it by now. But anyways a option you can do is to get something solid like a pot and put that over the air intake. Alos a plastic tote lid would work too. Cardboard may also work.
Old 08-19-2007, 10:03 PM   #3
lapeer20m's Avatar
unfortunately for you, a mechanically injected diesel will continue to run without any electricity.
unscrewing the fuel filter while she's running would probably be a little messy, but would certianly cause her to stall. Re-starting a diesel that ran out of fuel isn't the end of the world. Especially in a bus that has a flip up hood.
like the previous poster said, i'm sure you have it by now.
the fuel shutoff solenoid your'e looking for if it's a 6.6 litre 6 cylinder ford (or 7.8 litre) is on the passenger side plainly visible when the hood is open. I wish i had a photo. the solenoid is connected to a lever on the side of the injector pump. it'll only move one way...left or right i dont' remember, and the engine will shut off.
if it's a 6.9 or 7.3 liter, i'm not sure where the shutoff solenoid is, but it still has to be a lever on the side of the ip i would immagine. It might be difficult to find if you don't know what you're looking for.
Old 08-19-2007, 10:29 PM   #4
the_experience03's Avatar
I can go snap a picture of the solenoid right now if need be assuming you have a 6.6 or 7.8. Being that they need to be energize to open and spring closed I would start looking for a broken or worn spring or a grimed up cam mechanism since clearly it wasn't electrical current holding it open after you disconnected the alternator. I think a little bit of brake cleaner could go a long ways.
'87 Detroit Diesel 8.2L Ford B700 conversion -- help! caster Veggie Oil | WVO | Biodiesel | SVO 0 07-18-2014 11:37 AM
89 Ford B700 being scrapped for diesel driveline for wrecker Gateway-broker Mechanical and Drivetrains 1 10-02-2010 09:20 PM
Pics of 87 Ford B700 Blue Bus 6.6 Diesel lapeer20m Skoolie Conversion Projects 29 06-29-2008 06:12 PM
Convert Ford B700 from gasoline to diesel engine? Elliot Naess Conversion General Discussions 7 11-13-2005 12:23 PM
86 Ford B700 Turbo Diesel TravelingMan Conversion General Discussions 0 03-12-2005 03:01 PM
