Old 10-26-2009, 11:53 AM   #1
dreadballa's Avatar
Year: 1975
Coachwork: carpenter
Chassis: short bus fe.
Engine: 366ci chevrolet
running a freezer on a power inverter?
I have a small chest freezer modified with a refrigerator thermostat. (doesn't need to get as cold so doesn't have to run as long) I don't have the specs for power consumption, but I am trying to get the average size of power inverter used to power a 7 cu. ft. fridge, and if it is even possible to run it off a battery bank with a 350 watt solar recharging system and 6 8D size batteries.
dreadballa is offline   Reply With Quote
Old 10-26-2009, 05:52 PM   #2
Re: running a freezer on a power inverter?
You need 2 different numbers - the watts when running and the watt-hours per day. The watts when running could come from the data plate, and would be needed to size a big enough inverter. The inverter needs to supply peak power, not average power, and it needs to be big enough to start the compressor as well as keep it going.
The watt-hour per day usage is harder to figure. The best way is to plug the AC cord into a Power Angel or Kill-a-Watt meter, and let it add up the usage. Another way would be to find a scrap hour meter that would record how long the external thermostat supplies power, and multiply the daily hours by the data plate figure. The usage will change based on whether the freezer is in an unheated basement in Alaska, or on a sun porch in Arizona. The good part of this variation is that with solar, is there is more sun available when more cooling is needed.
Once you know your usage, you can figure the required battery and solar capacity. If you are short on cash, get more batteries than solar and top them off with a small genset every now and then.
Old 10-26-2009, 05:57 PM   #3
dreadballa's Avatar
Year: 1975
Thanks guys. That is some good info. I'll post pics when she's done.
Why I like lots of Freezer Space... lornaschinske Skoolie Life 11 06-25-2017 12:33 AM
Battery Power Inverter with Roof Mount AC logistix Alternative Fuels | Electric, Propane, Wood & Biofuels 8 11-25-2013 11:24 PM
Chest Freezer as 'Fridge in Bus swinada Heating, Cooling and Appliances 53 06-14-2012 10:00 PM
How to get 110 power while bus is running off 12v OfourTHREEfive Conversion Tutorials and How-to's 2 01-22-2012 10:04 PM
running a chest freezer on it's side. icnivad Heating, Cooling and Appliances 3 06-01-2010 05:47 PM
