Old 07-23-2016, 09:58 PM   #1
Year: 90
Chassis: international
Running ac and dc wires together
I have been searching the board and not finding the answer, I know it's out there just can't find it.
I read somewhere that you should not run ac and dc wiring close together.
can you? if not how far apart should the looms be?
Old 07-23-2016, 10:32 PM   #2
If you're running them in separate looms, that is sufficient. Ideally, you just don't want the individual wires touching. This is to avoid noisy power that can mess up a radio, etc. The NEC allows for both AC & DC (up to 600v) to be run together in the same race.
BusFiend is offline   Reply With Quote
Old 07-24-2016, 03:27 PM   #3
Year: 90
The main thing I heard about was induction voltage from ac to dc. not sure if thats true.
Old 07-25-2016, 01:40 AM   #4
when to close as in touching threes always the chance no matter hoe remote . That with chaffing insulation gets worn to the point you get 120 volt ac bleeding to your 12 volt system which will fry anything attached . then threes always the chance of getting zapped when you step off the bus .
I earlier posted why reinvent the wheel and put up a link to battery maintenance from a sailing mag I still get even though I gave up sailing several years ago they have many of the same problems rv'ing dose and the solutions work for us as well .
They actually have spec's and codes established by the industry and the governments .
Worth a look for ideas if no other reason .
electrical | Cruising World
Progress doesn't come from early risers — progress is made by lazy men looking for easier ways to do things.
mad_wolf is offline   Reply With Quote
Old 07-25-2016, 06:18 AM   #5
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Yes, AC can induce a voltage with no current in a DC circuit. Electricity is no joke; you can fry your gear and yourself. We can offer advice, but research the actual regulations.
For me, I was thinking of running two separate lines- AC down low, DC up high- and in their separate conduit.
Captain Obvious on deviantArt
Old 07-25-2016, 06:26 AM   #6
my DC wires are in welding cable then in convoluted tubing amnd placed in the bottom of a chaseway i made.. my AC wires are in the same chaseway at the top of it so theres a couple inches and a flexible A/C duct in the same chase, I have tested wit ha meter and havent seen any induced voltasges ion either side,, my AC and DC are a couple inches apart from each other..
Old 07-25-2016, 10:28 AM   #7
Carytowncat's Avatar
Hi,
I ran my ac line in the same track as my dc line from front to rear of the bus. when i play my stereo in the rear i get a whisker of hum that i can only hear when the music volume is so low i can barely hear music.
AC does induce noise into dc lines. Yes. If you are a sound engineer then by all means run em apart. Also i have these wires run along the floor, if ever there is a problem it will not be a hassle to change. If i were to run behind a wall with insulation.... i would probably run em a few inches apart.
Good question, and good luck!
