Old 12-28-2011, 02:06 PM   #1
Year: 1985
Engine: Detroit Motors 8.2
Running electric and door set up
I am trying to turn my bus into a commercial kitchen (roach coach). I have 6 4x4 outlets on each sid of the bus.
I will be running 12g thhn wire throu 3/4 emt conduit. The bus will have a divider wall abouty 4 ft back from the drivers seat. IN this wall will be the electric pannel just biased to the left of the door opening. Question: what is the best way to run the wires from one side of the bus to the other. I thought of drilling holes in the floor and running flex (liquid tight)conduit under the bus and up to the junction box on the other side. Has anyone done this?
For code reasons I can not shoot the bare wire up and through the roof.
2: is there anywhere to get a small swinging door for the divider wall? Or am I stuck making my own?
Thanks,
B_B
butcher_boy is offline   Reply With Quote
Old 12-28-2011, 02:13 PM   #2
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Re: Running electric and door set up
Thanks,
B_B
Lowe's and Home Depot and the like carry narrow louvered and solid doors meant to be used in pairs on closets.
If you want a ''saloon" door, maybe use an exterior window shutter.
Saloon door hinges make them swing - these seem kinda pricey, but they'll give you the idea -http://www.hingeoutlet.com/double_ac...ing_hinges.htm
Tom
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 12-28-2011, 02:17 PM   #3
roach711's Avatar
Rated Cap: 19
I would think the liquid-tight flex would work nicely. If you have the headroom, you could run a conduit above the door through the door frame.
The Roach Motel
Old 12-29-2011, 12:27 PM   #4
either below or as mentioned above will meet code as long as you use the right conduit. You didnt mention condiut size, or how many elect wires you are going to run.. if the conduit needed is more than like 3 inches, i would only run it underneith. I run mine undernieth where the first compartment is..
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 03:54 PM
I need an Electric Door opener for my Bus. 91 Bus Guy Classifieds | Buy, Sell, Swap 7 04-02-2014 10:23 PM
Electric key switch for power bus door roach711 Conversion General Discussions 7 01-02-2012 08:08 PM
Electric door lock somewhereinusa Conversion General Discussions 6 10-27-2011 09:19 AM
Electric back door lock...who posted the pics? Abbott Conversion General Discussions 4 08-11-2008 10:50 PM
