Old 05-27-2009, 01:41 PM   #1
TygerCub's Avatar
Engine: Detroit
Running Electrical Wires Outside?
While searching the web for other folks who are conversion nuts, I found a bus that used "black iron" pipe to run the propane line on the outside of the bus. It was stated that it made him feel safer knowing he could easily access any valves and joints in case of a leak. AND, if something happened to leak, it would be outside where it wouldn't asphyxiate him. Made sense to me.
But if one could do that with the propane, could one also do that with the wiring system? Either run the wires through metal conduit/black iron pipe on the exterior too, or hide them under the "rub rails"?
Any pros and/or cons to this setup?
P.S. - Going to look at another bus tonight. This one is already a toy hauler, so I'm hoping it's got a stronger engine. Wish me luck!
Old 05-27-2009, 01:58 PM   #2
lapeer20m's Avatar
Re: Running Electrical Wires Outside?
i've run wires on the outside on occasion. underneath a bus is a good place to run wires, especially when you want to get a wire from passenger side to driver side of the bus, or after you finished your conversion and forgot to run a wire. Most times i run my wires on the interior along either the chair rail at the bottom, or up in the space where the wall and ceiling come together. The wires are protected better and not exposed to the elements this way.
When i do run exterior wires, i usually use wire that comes inside flexible conduit like this.
Old 06-01-2009, 12:20 PM   #3
swinada's Avatar
But TECK is and should be used when you run something on the outside.
CSA Teck 90
Aluminum Interlock Armoured Power and Control Cable
-40°C to 90°C Rated
Home
Electronic & Electrical Index
Search
Previous Next
Application:
Teck 90 cables are used in the pulp and paper, mining, petroleum, and chemical industries, as well as, in commercial and industrial building applications. They may be used under the following conditions:
In ventilated, non-ventilated, or ladder-type cable trays in dry or wet location
exposed or concealed wiring in dry or wet locations
on walls or beams
directly buried
CEC Class 1 Div 1&2 Group A,B,C,D
-40°C (-40°F) dry or wet environments
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 06-01-2009, 07:15 PM   #4
TygerCub's Avatar
Engine: Detroit
Thanks, guys, for the links and ideas!
I must say, I'm rather frustrated right now. There is a bus I could buy, but it's not what I want. The bus I want, i can't afford to buy.
It's so very hard to be patient. Timing is everything, I'm afraid. I have the opportunity now to start building, and the weather is remarkably cool for this time of year. It would be the perfect time to start tearing out the interior and prepping for foam and framing.
As Baadpuppy said, "Be Patient Grasshopper".
But I want it ALL, and I want it NOW! (I know, I know... quitchyerbitchen)
Where do you put your batteries and wires? heathnlaura Electrical, Charging and Solar 6 01-19-2014 11:05 PM
How to get 110 power while bus is running off 12v OfourTHREEfive Conversion Tutorials and How-to's 2 01-22-2012 10:04 PM
Cover for unsitely wires putterspitt Conversion General Discussions 3 01-09-2011 09:25 AM
Running Electrical Outlets Diesel Dan Conversion General Discussions 2 12-05-2010 02:35 PM
Is anyone running on WVO? How do you like it? greyguzziart Alternative Fuels | Electric, Propane, Wood & Biofuels 5 02-02-2007 07:31 PM
